Mkv gti cam chain
shamalm
Car Model: MK5 gti
Mkv gti cam chain
Post by shamalm » Tue Feb 06, 2018 7:31 am
I have had my cam chain, tensioner and adjuster changed by vw 3 years ago and my car is still making that diesel sound.is it ad isable to just do tensioner now and see if it still xoes the same
'06 MK5 Gti - viezu sw and viper dp
'87 Jetta cli 16v exec
'03 mk4 gti - revo sw and fastcar exhaust
'85 mk2 gti 1.8 8v
Re: Mkv gti cam chain
Post by panic-mechanic » Tue Feb 06, 2018 11:01 am
clatterin on idle? Trademark of a BWA.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
shamalm
Car Model: MK5 gti
Post by shamalm » Tue Feb 06, 2018 3:20 pm
It is a bit loud though
'85 mk2 gti 1.8 8v
Dale
Post by Dale » Tue Feb 06, 2018 3:35 pm
shamalm wrote:It is a bit loud though
I have the same issue on start up each time, rrr for a while and then it stops, mine is a bit load as you stated as well.
I am not sure if this is lifter related or cam chain/tensioner related. Someone here mentioned, "could be warning signs of failing oil pump" (which i want to check the pickup this weekend). Tensioner and chain from agents - R2500. Lifter - R180 each
Then again, Car now has 305000 kms on the clock.
What is the kms on your car?
shamalm
Car Model: MK5 gti
Post by shamalm » Wed Feb 07, 2018 8:18 am
Mine is only 158 000km.had the sump service all done .
'85 mk2 gti 1.8 8v
Dale
Post by Dale » Wed Feb 07, 2018 9:30 am
shamalm wrote:Mine is only 158 000km.had the sump service all done .
Was anything replaced with the sump service?
shamalm
Car Model: MK5 gti
Post by shamalm » Wed Feb 07, 2018 9:42 am
Nothing on the bottom end.
'85 mk2 gti 1.8 8v
Post by panic-mechanic » Wed Feb 07, 2018 11:39 am
don't guess . If you thin there is oil pressure issues attach a physical gauge and look.
To change all the lifters and tensioner and chain is about R3800 in parts.
To rebuild the engine because the oil pump failed is in excess of R50k.
Don't guess. Make sure.
'07 Audi A4 2l TDI
Dale
Post by Dale » Wed Feb 07, 2018 2:25 pm
Although a gauge will be most accurate, will this work as well:
1. Hold down "ECON", and press the "up-vent" button (next to recirculation). Both temperature displays will read 00 or 00'0, and you can release the buttons once they do.
2. Twist the LEFT temperature knob until the display above reads 19’0.
3. Twist the FAN knob until the left temperature display reads 19’4 (like 19.4)
Is the preferred pressure between 3 and 5 on idle and driving and not exceed say 6 at higher rpm?
