Tfsi cam golf5 bwa
vwpro
Car Make: Audi Quatro, polo Beast and A3
Car Model: S3, Polo Playa,
Tfsi cam golf5 bwa
Post by vwpro » Thu Jan 25, 2018 7:58 am
Anyone by change got a golf5 bwa motor camshaft in good co dition that you can measure the lift on the lobes for the hpfp.
:troll:
Re: Tfsi cam golf5 bwa
Post by panic-mechanic » Thu Jan 25, 2018 8:01 am
From where to where do You want the measurement cause it's a triangle
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
Dale
Post by Dale » Thu Jan 25, 2018 8:59 am
panic-mechanic wrote:From where to where do You want the measurement cause it's a triangle
Thanks Stefan, was wondering about this the other day. The shaft on the right, that lobe replaceable on it own?
vwpro
Post by vwpro » Thu Jan 25, 2018 9:48 am
From the senter to flat part of the flat lobe edge then from senter to top of lobe subtract the 2 measurements and you will have the lift
:troll:
Post by panic-mechanic » Thu Jan 25, 2018 3:29 pm
They probably are if you can find a replacement but I don't know if VW sells something like that.
Maybe somebody aftermarket? I have never searched or tried.
I went to go measure a cam for you but forgot that blueblob took it to have something tested.
I'll ask him to take some measurements.
But If you say you changed the cam then I doubt it's that.
'07 Audi A4 2l TDI
vwpro
Post by vwpro » Thu Jan 25, 2018 9:15 pm
There are some audi's that runs on 90bar fp, it might be that vw stealership made a fuckup and supplied me with the wrong cam.
The 4 lobe tsi cams have a 3.5mm lift. I found a kit to mod the VAG TFSi Cam Follower To TSi Cam Follower Roller ...
:troll:
vwpro
Post by vwpro » Fri Jan 26, 2018 8:11 pm
Found the problem,
When pushed the fuel supply pipe onto the s/s pipe connected to the hpfp a peace of rubber sheer off and kind of blocked the fuel supply to the hpfp, cleaned out pipes and it ran like mouse with slippers, now I can fine tune the file to xxxbar boost and see what we get out on the wheels, last power run gave us plenty wkw on 1.9bar boost, plan to take it higher.
:troll:
Dale
Post by Dale » Mon Jan 29, 2018 9:29 am
vwpro wrote:Found the problem,
Have you ever... glad you managed to fix it. Agents would have replaced alot of stuff I recon.
