Good day gents,
Which would be the preferred plugs for my car ?
I replaced plugs recently from the stock BKUR6 to the BK7's gapped @ 0.7mm and experiencing alot of low down misfires when car is cold, but nothing under boost. I've read that chipped cars should use the 1 colder range but should I move back to the stock 1s ?
Do you need more mods and boost, maybe stage 2 map to use the colder range ?
1.8T stage 1 Plugs
- P1LAYA-ZN
- Car Make: Audi, VW and Toyota
- Car Model: S3 8L 20VT & Mk 1 Jetta GLi
Re: 1.8T stage 1 Plugs
No ise the same as stock
- Smok3X
- Registered for: 15 years
- Car Make: SEAT
- Car Model: LEON CUPRA 2.0 TFSi K04
- Membership No: 3083
I used NGK Iridium, BCPR7EIX Plugs on my 1.8T (I think that is the code...could also be BKR7EIX) but the standard plug gap (0.7mm I think) and they worked well on Stock, Stage 1 and Stage 2.
Check your Coil Packs are not faulty, this is a common 1.8T problem.
Leon CUPRA - 2.0TFSi K04--> Rides Thread
169WKW@Dark Artz - Stock
229WKW@Dark Artz - RevO 2+
Ibiza CUPRA - 1.8 20V - Hybrid Turbo-->Rides Thread
Revo:182KW and 399NM@Experience
ABF Citi Golf - 2.0L 16V--->Rides Thread
FRC - 124KW and 198NM@Auto Trix
1/4 Mile:14.61s
1ST Place - 4AF2 Margate 31st Oct 2010
1/4 Mile:14.61s
- P1LAYA-ZN
- Car Model: A3 1.8T
- Membership No: 1989
Most people on stage 1 stick with stock plugs (NGK Platinum PFR6Q).
Also if you are not comfortable with those there is also:
NGK BCPR7ES (Copper plug)
NGK BCPR7EIX (Iridium Plug)
All these are normally gaped to 0.7mm
- nico43
- Car Model: Polo gti 9n3
I use bcpr7es without any issues gapped at 0.63 but I've got hybrid turbo,when I still had stock turbo gapped it at 0.7 also no issues
Sent from my EVA-L09 using Tapatalk
- P1LAYA-ZN
Ok, will try reducing the gap from 0.7mm, if all fails, will go pack to the stock plug.
Thanks.
Thanks.
Honestly there is no good reason to run a colder plug. The engine was designed for that and even with upped boost you don't need a colder plug on stage 1 tunes. All you are doing is killing plug life.
