Car dies when slowing down 9n3 Gti
- Remzo
hi guys having some issues with my car
when slowing down the car dies and the battery light comes on i did scan the car and a few errors came up
please assist
thanks in advance
Sent from my SM-G925F using Tapatalk
please assist
thanks in advance
- Remzo
Re: Car dies when slowing down 9n3 Gti
just a small updated i cleared the codes again finally went away but the car still dies when coming to a stopRemzo wrote:hi guys having some issues with my car
please assist
thanks in advance
- Registered for: 20 years 5 months
If you start it up after that and let it idle what happens?
- Remzo
nothing it starts on the first swing and idles and boosts fine no limp mode or anything .....just dies when coming to a stop and the battery light comes on then i have to start it again
possibly a throttle body. Is it cable or DBW
- Pynoxim
panic-mechanic wrote:possibly a throttle body. Is it cable or DBW
dbw
- Registered for: 8 years 8 months
I dob't know if this could be similar to the problem I had with 2006 NA Mazda 6. Initial symptoms were similar, but progressively it worsened until it died during gear shifts. No error coded showed. Auto Electricians in Brentwood Park could solve it. It was towed to the dealer in Germiston. They used electric cleaning solvent to clean all earthing points, all electrical connectors, starting inside the car at the throttle sender and made their way to the engine bay.
The problem was resolved, it had more power & even the headlights were brighter.
- Remzo
bjx motor bro....DBWpanic-mechanic wrote:possibly a throttle body. Is it cable or DBW
- Remzo
should i try aligning the throttle body again?
Pointless but you can try. On DBW it does it automatically everytime you start the car.
I say throttle body as well, clean the throttle body and the "dying when slowing down" problem should go away.
I have seen this on many customers cars
Kinetic Garage
0849991860
0849991860
- nico43
- Car Model: Polo gti 9n3
I had the same issue but on my tdi and it was cam sensor.
Sent from my EVA-L09 using Tapatalk
tdi and gti is vastly different in how it does idling. There is literally no comparison at all.
- Car Model: A3 1.8T
- Membership No: 1989
The fact that the battery light comes on and a lot of faults say there are voltage drops/problems, maybe check all your earths and positive straps.
Also as Panic says it could be TB too, or it could be both.
- Remzo
ive done a big 3 up grade ...i replaced the charge wire from alternator to the battery with pure 4G copper cable ...and well as two grounds with 4gauge pure copper aswell ...the battery is holding charge aswell
- DES7
- Car Make: Fast ones
- Car Model: 1.8T GTi
I have seen 2 similar instances on Polo GTi's.
Are you modded? What mod's?
1. Throttle Body stays stuck and struggles to open re-when throttle applied but this hesitation can be felt when trying to accelerate again from lower speed.
2. Issue with piping or DV - basically a leak in the system.
Methanol Wotboxer
Ex - Polo 2.0i Blue magic
Black 135I 420wkw 834nm
Crimson red 135i
Present and Future : 2007 Polo GTi Unitronic. >283000kms
