Car dies when slowing down 9n3 Gti
Remzo
Post by Remzo » Sat Jan 13, 2018 9:39 am
hi guys having some issues with my car
when slowing down the car dies and the battery light comes on i did scan the car and a few errors came up
please assist
thanks in advanceImageImageImageImage
Remzo
Re: Car dies when slowing down 9n3 Gti
Post by Remzo » Sat Jan 13, 2018 12:32 pm
Remzo wrote:hi guys having some issues with my car
please assist
just a small updated i cleared the codes again finally went away but the car still dies when coming to a stop
windshear
Post by windshear » Sat Jan 13, 2018 6:52 pm
If you start it up after that and let it idle what happens?
Remzo
Post by Remzo » Sun Jan 14, 2018 4:54 pm
nothing it starts on the first swing and idles and boosts fine no limp mode or anything .....just dies when coming to a stop and the battery light comes on then i have to start it again
Post by panic-mechanic » Sun Jan 14, 2018 6:19 pm
possibly a throttle body. Is it cable or DBW
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
Pynoxim
Car Make: Lexus
Car Model: GS300
Post by Pynoxim » Mon Jan 15, 2018 2:55 am
panic-mechanic wrote:possibly a throttle body. Is it cable or DBW
dbw
Thursday Milkshake Crew
'00 GS2 Lexus GS300
MrMazda
Post by MrMazda » Mon Jan 15, 2018 9:26 am
I dob't know if this could be similar to the problem I had with 2006 NA Mazda 6. Initial symptoms were similar, but progressively it worsened until it died during gear shifts. No error coded showed. Auto Electricians in Brentwood Park could solve it. It was towed to the dealer in Germiston. They used electric cleaning solvent to clean all earthing points, all electrical connectors, starting inside the car at the throttle sender and made their way to the engine bay.
The problem was resolved, it had more power & even the headlights were brighter.
Remzo
Post by Remzo » Mon Jan 15, 2018 10:13 am
bjx motor bro....DBW
Remzo
Post by Remzo » Mon Jan 15, 2018 10:14 am
should i try aligning the throttle body again?
Post by panic-mechanic » Mon Jan 15, 2018 11:24 am
Pointless but you can try. On DBW it does it automatically everytime you start the car.
'07 Audi A4 2l TDI
kreevs_tsc
TSC Garage
Post by kreevs_tsc » Mon Jan 15, 2018 7:24 pm
I say throttle body as well, clean the throttle body and the "dying when slowing down" problem should go away.
I have seen this on many customers cars
TSC Garage
0849991860
nico43
Car Model: Polo gti 9n3
Post by nico43 » Mon Jan 15, 2018 7:41 pm
I had the same issue but on my tdi and it was cam sensor.
Sent from my EVA-L09 using Tapatalk
Post by panic-mechanic » Mon Jan 15, 2018 8:29 pm
tdi and gti is vastly different in how it does idling. There is literally no comparison at all.
'07 Audi A4 2l TDI
Breadroll
Car Model: A3 1.8T
Membership No: 1989
Post by Breadroll » Tue Jan 16, 2018 2:37 pm
The fact that the battery light comes on and a lot of faults say there are voltage drops/problems, maybe check all your earths and positive straps.
Also as Panic says it could be TB too, or it could be both.
Remzo
Post by Remzo » Tue Jan 16, 2018 2:47 pm
ive done a big 3 up grade ...i replaced the charge wire from alternator to the battery with pure 4G copper cable ...and well as two grounds with 4gauge pure copper aswell ...the battery is holding charge aswell
DES7
Car Make: Fast ones
Car Model: 1.8T GTi
Post by DES7 » Thu Jan 18, 2018 2:49 pm
I have seen 2 similar instances on Polo GTi's.
Are you modded? What mod's?
1. Throttle Body stays stuck and struggles to open re-when throttle applied but this hesitation can be felt when trying to accelerate again from lower speed.
2. Issue with piping or DV - basically a leak in the system.
:evil: Methanol Wotboxer
