Help needed...
Help needed...
Hi guys. My coolant light on my Audi a4 came on and when I lifted the bonnet I saw water squirting from this pipe. I don't know what to do now as its a public holiday and most car shops are closed.
Can I used Qbond in the interim?
Pls help
Sent from my ZTE T920 using Tapatalk
Pls help
- Membership No: 2033
Re: Help needed...
Depending.....I'd use a self taper screw and then use some of that self valcanising tape to cover it.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Re: Help needed...
Qbond uses superglue, and that stuff is not waterproof. It might last for a few days.
Do what Howie suggested.
- dcmk4
- Car Model: MK7 GTi
Re: Help needed...
Qbond supposedly can handle up to 180 celcius and can be used with coolant without a problem.
Perhaps try what Howie stated, then throw some qbond around the bolt to seal it up for now.
Re: Help needed...
Metal pipe
Whip it off an find someone who can braze it.
Should last a while and should safely get you home from your holiday
Re: Help needed...
Thank you gents. Much appreciated
I inserted a self tapper crew and some Qbond.
Will sort it out tomorrow...hopefully I can get it sorted tomorrow.
Re: Help needed...
Some update...
I replaced the pipe however the owner at the workshop said I don't need antifreeze but is going to throw in aquaclear. Any one else used this?
- Pynoxim
Re: Help needed...
I would use antifreezeCarlitoCPT wrote:Some update...
Re: Help needed...
Use a different workshop in future. Aquaclear is marketing BS.
Use G12 coolant from Goldwagen.
Re: Help needed...
Should I drain the water and refill it with water/coolant again rather?
Re: Help needed...
Coolant is not just anti freeze. it has some anti rust properties as well which water / aquaclear won't have
