Howsit guys.
I need help. I know how to log my car , want to test and see of there is gonna be a diffrence in timing pull with diffrent fuels
I know for a fact under load the car pulls about 6 degrees negative timing after a run or 2 in this lovely summer heat. So want to see if higher octane will fix this in a way. Seems like she loses her power from 4000rmp ish upwards.
What should the timing pull be ? Still a noob amd trying to learn more , but google makes it confusing
I know that less timing pull , more to the 0 sode is better and advancing it can cause probs if not running higher octane fuel ? Correct ?
Lets talk VCDS logging
- Jacques1397
- Car Model: Citi Rox 1.4i & Golf 5 GTI
- Membership No: 1970
Current :
2007 Golf 5 GTI
2008 Citi Rox 1.4i - Daily
Ex :
2009 Polo 1.8t GTI Stage 2
2007 Golf 5 GTI
Ex :
- Car Make: SEAT
- Car Model: Leon Cupra
Re: Lets talk VCDS logging
More information about your car.
Mods, mileage, besides timing pull how do the rest of your logs look? i.e. AFR, Fuel Pressures etc.
- Jacques1397
Planning on running the logs nowDazzG_177 wrote:More information about your car.
Will do 2 logs. One with Fueling and one with Timing.
Mk5 GTi 2007 model. FR&R stage 2 with K04 , intake and downpipe. I know the heat causes heatsoak and then pulls timing - Then gonna run more logs with NF Ultra mixture to see if the timing improves or stays the same. Just need to pinpoint the reason why she loses power on top end. Although mechanically everything is perfect as far as it seams. Just the heatsoak issue. Has an Aftermarket Nuespeed 14 Row cooler aswell
Current :
2007 Golf 5 GTI
Ex :
2007 Golf 5 GTI
Ex :
- Committee Member
- Car Model: Audi S3 Sedan
- Membership No: 1215
Timing pull should be 0 or as close to 0 as possible
Fuel mix will aid timing pull, However the car never had timing pull up here so I never used additives, so cant say
rule of thumb is anything over 3deg should be looked at, however 6 is not to bad considering the heat in Nelspruit
A better solution over fuel additives is WMI
When logging look at air temps, it use to run about 6 deg above ambient in JHB on hot days, and 2 deg above on cold days, which is very good for a FMIC only, WMI will get it below ambient easily
Grant Hendry
Membership no.:1215
2016 Audi S3 Sedan
1978 VW Golf 1100 GL
2012 VW Golf GTI Edition 35
2007 VW Golf GTI
2006 Polo 1.9 TDI Sportline
2012 VW Polo GTI
Membership no.:1215
2016 Audi S3 Sedan
2007 VW Golf GTI
2012 VW Polo GTI
- Jacques1397
For sure. Nelspruit heat is just a beeach . But nothing wrong with the rest of the car. Just need to find a solution for now. WMI planned soon but currently out of budget.G-spot wrote:Timing pull should be 0 or as close to 0 as possible
Will add the ambient temp to the logs and see what happens.
Posting logs here as soon as I have them
Current :
2007 Golf 5 GTI
Ex :
2007 Golf 5 GTI
Ex :
- Membership No: 2033
Seems? or does?Jacques1397 wrote:Seems like she loses her power from 4000rmp ish upwards.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Jacques1397
Can notice heatsoak. So surely losing a bit. Teated earlier. Got max -3.8 degree on a cylinder. Not too bad. Was my 1st run. After that gets a bit worse. Got the NF now so will test again.Howie-WP wrote:Seems? or does?Jacques1397 wrote:Seems like she loses her power from 4000rmp ish upwards.
Tested at 12 @ 30 degrees and 80 % humidity. So sure by tonight when we have some drags and the NF worked into the system it should run better.
For some reason my VCDS freezes after about 2 r 3 minutes into the log. So I will do another one and test in 1 gear to see diffrences
Current :
2007 Golf 5 GTI
Ex :
2007 Golf 5 GTI
Ex :
