Fuel in the oil
Mvuyiso
Fuel in the oil
Post by Mvuyiso »
Hey guys,
Had posted last week about my car having a misfire and low oil pressure light. Anyways it turns out the reason the oil light came on was cos the fuel was mixing with the oil somewhere, did an oil change, and the dip stick still smells strongly of fuel.
Any reason as to where or why the fuel and oil are mixing?
FYI, last mod I did before this started was HPFP
Car is 8p S3 CDL
Shadows101Fall
Re: Fuel in the oil
Post by Shadows101Fall »
Over fueling in its moer in. Get a diagnostics done. You will **** up your block if you keep on driving like this, alternative, go back to stock fuel pump and clean oil.
Mvuyiso
Re: Fuel in the oil
Post by Mvuyiso »
Hey dude, tried a stock pump yesterday.. same result. Planning on trying a different o2 sensor now. Hoping this one is just f***ing out
s3 freak
Re: Fuel in the oil
Post by s3 freak »
Hpfp is leaking fuel into the oil...
Re: Fuel in the oil
Did you try a new pump or a old stock pump. It can be the same problem on both and common on a used/old if they have been sitting on a rack for a while.
Last edited by panic-mechanic on Mon Nov 27, 2017 8:05 am, edited 1 time in total.
Neuk
Treasurer
Treasurer
Membership No: 806
Re: Fuel in the oil
Post by Neuk »
panic-mechanic wrote:Did you try a jew pump or a old stock pump. It can be the same problem on both and common if they have been sitting on a rack for a while.
Are these pumps more stingy with fuel?
Re: Fuel in the oil
Very stingy.
Mvuyiso
Re: Fuel in the oil
Post by Mvuyiso »
Lol.. well it wasnt a new pump, but my thinking was what are the odds they both bad? Thinking the lambda sensor is bad today but is it possible that overfueling can over fuel to an extent whereby there's fuel in the sump?
Mvuyiso
Re: Fuel in the oil
Post by Mvuyiso »
Mvuyiso wrote:Lol.. well it wasnt a new pump, but my thinking was what are the odds they both bad? Thinking the lambda sensor is bad today but is it possible that overfueling can over fuel to an extent whereby there's fuel in the sump?
And yeah, the other pump had been sitting for a while....
Re: Fuel in the oil
Bad lambda will show up in a scan and will never cause fuelling to go to the point where it puts so much fuel in the oil that you notice it. They have a logical shutoff point in the management where it will stop considering a lambda reading
dcmk4
Car Model: MK7 GTi
Re: Fuel in the oil
Post by dcmk4 »
s3 freak wrote:Hpfp is leaking fuel into the oil...
My initial thoughts too, if that can happen..
'14 Golf Mk7 GTI
THANAS STG/// ECU&DSG
Littco L380x
All the ponies
Mvuyiso
Re: Fuel in the oil
Post by Mvuyiso »
panic-mechanic wrote:Bad lambda will show up in a scan and will never cause fuelling to go to the point where it puts so much fuel in the oil that you notice it. They have a logical shutoff point in the management where it will stop considering a lambda reading
Haha I wish I'd checked this post sooner, yeah well it was a waste of time Image
Mvuyiso
Re: Fuel in the oil
Post by Mvuyiso »
Well my next creative way of wasting money is having the injectors reconditioned. Will take the car to a proper garage now tho. Here's to hoping my warranty pulls through
Re: Fuel in the oil
well being in randburg why don't you pop into volkswagen hatfield and speak to Morne Lourens.
Mvuyiso
Re: Fuel in the oil
Post by Mvuyiso »
Decided to tow it to Yosh later this week rather rather, thought about the dealer route but wasn't sure how they'd feel touching a modded car
Mvuyiso
Re: Fuel in the oil
Post by Mvuyiso »
Well as panic mentioned, the issue was just a bad HPFP seal, which thanks to VW warrants a new hpfp lol. Thanks guys
