MK4 GTI Alarm problem
Hi guys. I need help with alarm issues on a MK4 Gti. A buddy of has a MK4 Gti and the alarm keeps arming itself when the car is switched off. Even if one of the doors are open and key out ignition, the alarm still arms itself. Has become a problem coz he locked his key in the car twice this month. What could be the problem and why is this happening. Any recommendations on how to fix this issue. Any help and info would be highly appreciated.
Re: MK4 GTI Alarm problem
Is there any way to bypass ithe and still have the alarm working. Is there something that can be done in vagcom?
- Membership No: 3103
It must be frustrating, it can be many things and I have been through that myself.
Does your remote lock/unlock the car? Because if you unlock manually by the key, you have to turn the ignition on within few seconds otherwise the alarm will go off. Try lock/unlock with the key itself and see if it helps.
Like THANAS mentioned it can be a door lock module. Does the fuel pump turn on when you open the driver door? Does the door chime sound when you leave the key in the ignition and the door is open ? Just test to see if everything around the driver door works normal, removing the key from the ignition should also unlock the door. All other doors and the boot you can check using the interior light to see if all is well.
You may also check the Comfort Control Module under the steering which can also make the alarm to malfunction.
Vagcom should be able to give you all errors that are relevant. Check mine below. Good luck
01134 - Alarm Horn (H12): No Signal/Communication
Possible Symptoms
## Anti-Theft Alarm sporadically triggered
Possible Causes
## Fuse(s) faulty
## Wiring and/or Connector(s) from/to Alarm Horn (H12) faulty
## Alarm Horn (H12) faulty
and
00928 - Locking Module for Central Locking; Front Driver Side (F220): Implausible Signal
Possible Symptoms
## Door Locks not working properly
Possible Causes
## Wiring/Connectors from/to Locking Module for Central Locking; Front Driver Side (F220) faulty
## Voltage Supply for Locking Module for Central Locking; Front Driver Side (F220) faulty
## Door Lock Mechanics are stiff/partially seized
## Locking Module for Central Locking; Front Driver Side (F220) faulty
Possible Solutions
## Check Wiring/Connectors from/to Locking Module for Central Locking; Front Driver Side (F220)
## Check Voltage Supply for Locking Module for Central Locking; Front Driver Side (F220)
## Check Door Lock Mechanics/Operation
## Check Locking Module for Central Locking; Front Driver Side (F220)
00928 - Locking Module for Central Locking; Front Driver Side (F220): Incorrectly Equipped
Possible Symptoms
Possible Causes
## Incorrect Door Lock installed
Possible Solutions
## Check Locking Module for Central Locking; Front Driver Side (F220) ## Check Door Lock Part Number
Possible Symptoms
Possible Causes
## Fuse(s) faulty
and
Possible Symptoms
Possible Causes
Possible Solutions
Possible Symptoms
Possible Causes
Possible Solutions
'09 8P S3 Sportback (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
Thanks for the reply. This will certainly help. Think I will try to remover the door lock module on the driver side door and check there are no dry joints.
- Mlungupokl
- Car Model: Mk4 TDi
Hi,
have you won yet?
I have had the same issue on my mk4 tdi.
Its usually door locks.
To temporarily bypass the issue remove the fuse for the CCM (comfort control module) but that will leave you without central locking, alarm, interior lights, door chime when lights are on and the lights at the bottom of the doors, but you can open and lock the car with the key in the drivers door.
Before you do that however check if any of the door check lights (the ones that usually light up when you open the door) stay on all the time or dont come on when you open the door. Even if you have an "open door" light on the cluster. This will help you narrow down which door lock module is faulty if you dont have a scanner.
This is a common issue with the MK4's. the soldering on the PCB's inside the door lock module fail over time. new locks are k*k expensive from the agents. I imported new ones over ebay.
have you won yet?
Thank for that. I figured it is the door lock modules but haven't had time to strip it down and check the solder joints. Hopefully will have some time this weekend to check it.
