Rattling noise from the engine bay
kingozzi
Registered for: 6 years 8 months
Car Model: PGTI1.4tsi 172kw 309nm(crank)
Post by kingozzi »
Howzt guys
I have a 2013 polo 6r gti that makes a rattling noise during cold start( on incline or decline) or if it has been parked for more than 3 days. So i took it to vw thinking its "the timing chain tension issue" :bang: .. to my surprise VW said its a turbo :crazy: so i tried to get the mechanic to explain exactly whats wrong with the turbo and he said its a "wastegate". Now id like to know symptoms of a bad Wastgate.
turbowheelchair
Registered for: 7 years 1 month
Car Model: Golf MK5 2.0 TFSi
Re: Rattling noise from the engine bay
Post by turbowheelchair »
On my Golf, the waste gate came loose, there is a threaded rod with a nut on it that when tightened, compresses a spring that holds the wastegate shut against an opening in the exhaust side of the turbo, when it is loose it rattles,
I only heard it rattling when the car was idling, when I rev it and then just before the revs could come down to idle you will hear that sound.
my tuner instantly told me its the wastgate when he heard it.
kingozzi
Post by kingozzi »
But mine rattles only on cold start.. was it an easy fix?
UDC
Membership No: 1041
Post by UDC »
My work vivo had a rattling noise, turned out to be the chain as the tensioner was on its last lapse.
You could hear the rattle sound at ever gear change whilst the rev dropped when you pressed the clutch to change gear.....even more so at higher rpm
turbowheelchair
kingozzi wrote:But mine rattles only on cold start.. was it an easy fix?
if they say its the wastegate its worth checking,
it was easy enough for me, but I enjoy getting under my car,
just go under the car and see if its loose, remove the heat shield around the drive shaft for access, you will probably battle to get to the nut to tighten it, but you will easily be able to feel if it is loose,
I watched a few videos of YouTube to see how to adjust a wastegate and then did it myself,
or you can pay someone to do it,
Ashveer03
Post by Ashveer03 »
Highly unlikely for a wastegate to only rattle on a cold start. It should rattle all the time as turbowheelchair said.
Since u mentioned "been parked for 3 days", seems as its some sort of lubrication issue.
Not sure of the 6r gti, but if its chain driven then u might want to get a second opinion.
U could also add an oil additive to give extra protection on cold starts.
kingozzi
Post by kingozzi »
It is Chain driven and i believe its a "chain tension" just dont know who to trust around here if vw is diagnosing s@#t
Ashveer03
Post by Ashveer03 »
Where are u situated?
kingozzi
Post by kingozzi »
East london Eastern cape
Ashveer03
Post by Ashveer03 »
Wait for somebody to suggest a reputable workshop in that area
53758
Registered for: 3 years 10 months
Post by 53758 »
Hi I have a 2013 polo gti and everytime on a cold start I hear this rattling sound, bt when I drive it goes away. I once had this pblm b4 and VW said it was the time chain and that was fixed, so what might b the case now since the sound is back?
