Esp light stays on.. polo gti 9n3
- Car Model: Polo Gti 9n3, Golf 5 gti.
Howzit guys
I need some help on my esp light .. It doesn't want to go off or on ... I recently change my stock dv to forge and ever since my esp light stays on the dash ..when i start its off as i drive it comes back on..I put the my stock dv back still stays on.. Did some research about the maf sensor gone bad ,so I changed it and still does the same .. also my cold start stopped working
- Pynoxim
Re: Esp light stays on.. polo gti 9n3
Scan it with VCDS and all will be revealed
Okay ... bro
Do you know anyone??with not too killer prices lol
- Pynoxim
What does ESP have to do with a maf or dv?
I believe the ESP (traction control) gets its signals via the wheel speed sensors, sensing rotation differences of the wheels..?
location location location. why don't people get it when they ask for help.
- Car Make: Vw, Bmw, Merc
- Car Model: 81 Vw Mk1 Cabrio,15 Mk7GTi
- Membership No: 3258
I USED TO HAVE THAT ISSUE ...WHEN I CHANGED BRAKE PADS IT WENT AWAY BUT HONESTY I HAVE NO CLUE WHY.
MAYBE SOMETHING IS LOOSE THERE BUD .THE CABLE FOR THE BRAKE PAD SENOR WAS BROKEN OFF SO I DONT KNOW IF IT WAS THAT...
I KNOW THIS ISNT MUCH HELP BUT HOPEFULLY YOU CAN FIND THE ISSUE OH AND ANOTHER THING THAT MIGHT HAVE HELPED ,WHEN I WAS CHANGING PADS I NOTICED ALOT OF GREASE AND GUNK AROUND THERE AT THE BACK OF THE CALIPER SO I KIND OF CLEANED ALL THAT EXCESS **** AWAY . WHEN I STARTED THE CAR AND TOOK IT FOR A DRIVE THE LIGHT WAS OFF:)
- MarshallGTi
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
ESP light on my 1.9TDi came on when the brake globes popped and went away after new globes so check that.
also check the brake light switch.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
- Car Model: '13 PGTI DSG
As stated above all the possible culprits are:
Your MAF sensor
Your wheel speed sensor (either damaged or lose connection or dirty)
Brakes (Brake switch on the peddle or brake light bulbs in your rear lights)
Your MAF sensor
Esp or epc? I havnt seen esp on polo tdis, thought only the seat tdis have the functionMarshallGTi wrote:ESP light on my 1.9TDi came on when the brake globes popped and went away after new globes so check that.
- MarshallGTi
- Car Make: Seat
Ibiza FRAshveer03 wrote:Esp or epc? I havnt seen esp on polo tdis, thought only the seat tdis have the functionMarshallGTi wrote:ESP light on my 1.9TDi came on when the brake globes popped and went away after new globes so check that.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
