MK5 gti "Rev hang"
MK5 gti "Rev hang"
Hi guys,
Been in exile for a while.
I need assistance with a weird issue. Basically as topic states, the rpm doesnt drop instantly when changing gears, as if it hovers around 1500 - 2000 rpm for a few seconds
Anyone have any idea what could cause this? Would a throttle adaptation cause this?
No other abnormalities with VCDS.
Mods include:
Engine - BWA
ITG intake
Software, done - unknown.
Manual transmission
Full Exhaust - rear silencer kept.
Thank you.
Mods include:
Engine - BWA
ITG intake
Manual transmission
Thank you.
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Re: MK5 gti "Rev hang"
Possibly the PCV valve giving up.
Clutch switch. Does it have cruise control. See if it engages - if not replace the clutch switch.
- Registered for: 15 years 5 months
ThisKillerwatt wrote:Possibly the PCV valve giving up.
Thanks,
Will give the valve a blow and clutch switch a check.
- Le Clue
- Membership No: 1458
Panic... how big of a job is it to replace the switch?panic-mechanic wrote:Clutch switch. Does it have cruise control. See if it engages - if not replace the clutch switch.
My manual R has the rev hang every now and then... this after I replaced the PCV.
Sent from my iPhone using Tapatalk Pro
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
Similar to a brake switch.
Edit- mm no the audis had it on the pedal. Some of the golf might have the switch on the gearbox.
- Jacques1397
- Car Model: Citi Rox 1.4i & Golf 5 GTI
- Membership No: 1970
Mine was the Clutch Switch - Panic also gave me the advise to replace
My Cruise control wasn't engaging. I have a 2007 G5 GTI - You buy a new clutch master cylinder from Goldwagen , and it clips into the Clutch pedal from the Firewall. You need to remove the whole master cylinder and replace it. Bleed the clutch again and all sorted. Quite a mission if you dont have the correct tools , specially to get the clips back into the pedal.
Current :
2007 Golf 5 GTI
2008 Citi Rox 1.4i - Daily
Ex :
2009 Polo 1.8t GTI Stage 2
2007 Golf 5 GTI
Ex :
it not abnormal or a problem its programmed into the ecu for emission reasons. https://www.carthrottle.com/post/rev-ha ... s-hate-it/
