PCV blank causing clouds of smoke
- Legion739
- Car Model: A3 2.0T - K04
I've had a PCV blank on my car for ages, no issues
Then did a K04 conversion and I noticed that if I stand on a up hill my car starts smoking white smoke like crazy, as in clouds.
It will sometimes also randomly start smoking like crazy in traffic.
I put my stock PCV back on, and had zero smoke, drove around like that for weeks not a drop of smoke.
Yesterday I put the PCV blank back on to test it, car ran fine but smoked, then this morning when I started my car (It was 5deg outside) It would start and then idle for about 5sec and die.
Put stock PCV back on and the problem disappeared.
I'm not going to put the PCV blank back on my car as it just seems to cause shlt, but I want to get to the bottom of why the PCV blank causes smoke, something must be wrong or blocked and I want to figure out what so I can fix it.
PS. I have a BWA motor (Mk5 GTI motor)
Re: PCV blank causing clouds of smoke
Put pictures of your blanking kit.
- Legion739
panic-mechanic wrote:Put pictures of your blanking kit.
This is the best pic I have at the moment, I can take better pics later if required. (This setup worked for months without issue)
This exact PCV blank was on a friends S3 for at least a year, without any issues
- Le Clue
- Membership No: 1458
A few guys have been complaining about the same issue with non OEM PCV solutions (block offs and catch cans)... so I’m in 2 minds as I need to replace mine...
Sent from my iPhone using Tapatalk Pro
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- Legion739
I've also seen on some forums people experience the same issues, but removing the Blank off feels to my like treating a symptom and not the cause of the problem.Le Clue wrote:A few guys have been complaining about the same issue with non OEM PCV solutions (block offs and catch cans)... so I’m in 2 minds as I need to replace mine...
My 2 cents is that the blank off forces all the fumes through the rear PCV and into your turbo hot side ...hence the smoke
Try the re-route to the catch can solution else just stick to the OEM PCV
it could be exactly that.
White smoke can also indicate a leaking brake master cylinder, I know that it seems you may have your solution, but check to eliminate it as a cause to your problem.
- Donnie Darko
- Colonel
- Membership No: 1834
I have had Pcv block offs on a couple of vehicles and none of them smoked with the block offs. My ED35 has been running one for over 10000km and no smoke(touch wood). I might look into a catch can later on. The charcoal canister needs to be moved then .
Ex: 2016 BMW M4
Ex: 2016 Audi RS3 8V
Ex: 2016 VW Golf 7 ED40 Clubsport DSG
Ex: 2012 VW Golf 6 ED35 Manual - 342WHP and 500NM
Ex: 2015 BMW F21 M135i Sport Auto - 393.2WHP and 639NM
Ex: 2013 BMW F20 M135i Sport Auto - 332WHP and 626NM
Ex: 2012 Golf R DSG - 300WHP and 473NM
Ex: 2010 Scirocco DSG 155KW - 300.8WHP and 416NM
Ex: 2008 Ford Focus ST - 262.2WHP and 425NM
Ex: 2006 Golf 5 GTI DSG
- Car Model: S3, Polo Playa,
Vdubstar wrote:My 2 cents is that the blank off forces all the fumes through the rear PCV and into your turbo hot side ...hence the smoke
If to much fumes causing the smoke then you will have sump compression causing the smoke and a lot of oil will accumulating in the boostpipes.
Do a check when you have the pcv blank off installed remove the pipe that clip on it from the bottom end and rev the motor and see if some fumes comes out the blank off and unclipped pipe from the botton.
Healthy motor is not suppose to have a lot of sump compression.
- Legion739
Many Many Many guys use this PCV blank without issues or smoke though... so it has to be something elseVdubstar wrote:My 2 cents is that the blank off forces all the fumes through the rear PCV and into your turbo hot side ...hence the smoke
- Legion739
How much of a bltch is it to check ?missioner wrote:White smoke can also indicate a leaking brake master cylinder, I know that it seems you may have your solution, but check to eliminate it as a cause to your problem.
and won't the white smoke still be there with OEM PCV ? as when I put the OEM part on there is no smoke
- Legion739
I think my OEM PCV is farked, and Blank is causing smoke.vwpro wrote:Vdubstar wrote:My 2 cents is that the blank off forces all the fumes through the rear PCV and into your turbo hot side ...hence the smoke
When I pull out my dipstick with OEM PCV it sucks in air through there and dies.
Will swop it out and see what's up
- Le Clue
Did the Forge PCV block off and no issues so far..
Previous Rides:
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- Legion739
Cool, I had this PCV blank on my car for over a year, no issues and before that a friend of mine had this exact PCV blank on his with no issues.Le Clue wrote:Did the Forge PCV block off and no issues so far..
But my car smokes on idle when it's on now.
- marzbars
- Car Model: 1988 Corrado 16V
- Membership No: 1316
What software do you have?
Current : 1988 VW Corrado
Ex : 1990 VW Golf CSL 1.6
Ex : 1995 VW Caddy 2.0 8v
Ex : 1996 VW Golf 3 GTS 1.8i
Ex : 1995 VW Golf 3 GTI
Ex : 1993 VW Chico 1.3
- Donnie Darko
- Colonel
Glad you listenedLe Clue wrote:Did the Forge PCV block off and no issues so far..
Ex: 2016 BMW M4
- Legion739
How is this relivant ?marzbars wrote:What software do you have?
- Booth1982
- Car Model: 2003 S3 (Stock)
Good Morning I seem to be having the same issue but Mine is on a 1.8T S3 BAM engine, i have fitted a catch can and installed a blanking plate and everything was running fine for a year or so, but now when standing on an uphill or sometimes in traffic it smokes white smoke it looks like its vaping...
wondering if it has anything to do with the catch can or something of the sorts
any advise would be greatly appreciated.
Could also very well be turbo that is in need of some love if all was well for a long time and nothing was changed recently.
