16vt intermediate shaft pulley
Re: 16vt intermediate shaft pulley
Called Goldwagen de la Rey, Boksburg, edenvale, no stock. Which branch do u think might have stosk
Always try CBD. But also try places like Alert motor spares or Litts 200 in Kempton. Litts often stock Schadeck or can get for me.
Thanks so much Panic, you are a star
I must ask for a 2lt 16v abf oil pump right or is there another description?
yup just ask for 2l 16v pump. as soon as you say abf there is some sort of confusion becuase it was not locally available.
Thanks Panic, really appreciate your help
Is there a difference between the 16v pumps i.e. 1.8 16v versus 2.0 16v or is a 16v pump a 16v pump.
2l 16v pump had a taller body and longer gears which gave more oil volume. so no they are not the same. But 2l 16v shortblock and the ABF had the same pump.
Great so golf 2, 2lt 16 valve oil pump is what I can ask for because they keep asking which car or which engine
Hi guys, does anyone know of an engineering shop opened tomorrow to remove a broken bolt from the intermediate shaft?
- vadia
- Car Make: vw,nissan,merc
- Car Model: mk1,np300,c200 amg,gti7
hi its easy drill a small hole on both sides like a 3mm hole and use a ser clip pliers and try twisting it out coz it would come out easy becos there is no tension on it
opel monza cd
ford xr3i
mazda 626 200i egi
ford bantam
vw beach buggy
vw mk1 2.0 8v turbo
ford xr3i
mazda 626 200i egi
ford bantam
vw beach buggy
vw mk1 2.0 8v turbo
Hi guys, will the 1.8T 20v intermediate shaft and pulley work on a 16v abf engine?
I don't think it will. That should have the big gear where you need the small one. but just measure the gear size.
- Car Model: S3, Polo Playa,
Dont think the 1.8l 20v have a intermediate shaft, there sits a water pump where 16v shaft sits and it have a chain drive oilpump
There is the early 20vt that is basically the same old motor with external waterpump. Quite scarse by now and very few people seem to remember them.
I had two different ones in golf 1's as they bolt in straight without any engine mount stories.
APU engine code.
And right here is your answer. I has the big gear shaft. Won't work
https://www.youtube.com/watch?v=KciYhmddkBY
APU engine code.
That's the one, first 20v, I think it came out in Audi. I need an intermediate shaft but can't seem to get one. They say that it uses the same cam belt as the abf
Yeah The belt is the same but the intermediate shaft has the big gear. Won't work. You need a shaft from AAL , 9A or ABF. those are really it.
You can also modify shafts from 2E, AGG, ADY etc. - the 2l 8v's
Can I use the pulley though?
I'm sure I can get the thread out, just really need the pulley and key
yes pulley will be the same. but honestly you can buy the pulleys new still even from VW.
That I didn't know, thanks a stack,
Thanks guys, intermediate shaft and pulley sorted. The only oil pumps that I can source is topran or vika. Which of these are a better pump or perhaps u guys can get a different brand?
In that case take any one of the two.
I managed to get my hands on a KS oil pump. Received the head from engineering so time to assemble.
