Golf 7 GTI Vibration - Problem fixed
- ruler_70
- Colonel
- Car Model: Golf 7 GTI
Hey guys,
So last night i took the car out on the highway for the first time.
I noticed a slight intermittent vibration that only happens in 6th gear when the car is under load, ie. when at around 120km/h and accelerating on an uphill.
It doesn't happen every time, but sometimes a slight vibration can be felt when doing this. (the RPM at this point is around 2200-2300rpm.)
What i want to know is if this is normal due to the gear ratio's on the GTI, could the vibration be caused because i should be in a lower gear, or is this something else?
Thanks in advance.
Thanks in advance.
Current: 2018 Golf 7.5 GTI
Ex: 2016 Golf 7 GTI
Ex: 2014 Audi A3 Sportback 1.8T
Ex: 08 Silver Bird Polo GTI
Ex: 06 Polo 1.6i Comfortline
Ex: 98 Mk3 Golf GSX 1.8i
Ex: 2016 Golf 7 GTI
Re: Slight Intermittent vibration under load - Golf 7 GTI
Yeah that kind of RPM and trying to pull under full load is not healthy and could cause a vibration. 4 Cyl motors don't like that kind of thing much.
- ruler_70
- Colonel
So i took the car out on the highway again and realized it wasn't gear related afterall.panic-mechanic wrote:Yeah that kind of RPM and trying to pull under full load is not healthy and could cause a vibration. 4 Cyl motors don't like that kind of thing much.
There is a vibration coming up through the seats, so much so that the passenger seat shakes visibly.
From the googling i've done, it seems like it could be unbalanced rear wheels.
Ex: 2016 Golf 7 GTI
Ex: 2016 Golf 7 GTI
Gee ok that is not really a minor vibration or slight vibration as you were saying in the first post.
- MaX
- Membership No: 1802
Yeah, definitely not engine related. I've also got a slight vibration at that speed and it only started since I rotated tires. Not going to spend R6k on 2 tires to fix it though. (tires are balanced and aligned)ruler_70 wrote:So i took the car out on the highway again and realized it wasn't gear related afterall.panic-mechanic wrote:Yeah that kind of RPM and trying to pull under full load is not healthy and could cause a vibration. 4 Cyl motors don't like that kind of thing much.
2014 BMW F30 335i(A) ActiveHybrid3
2015 Golf VII GTI DSG Performance Pack
ex:2011 Polo GTI DSG
2011Jetta 2.0 TSI (CAW)
- ruler_70
- Colonel
Yeah from all the googling I've done, it seems tyre related.MaX wrote:Yeah, definitely not engine related. I've also got a slight vibration at that speed and it only started since I rotated tires. Not going to spend R6k on 2 tires to fix it though. (tires are balanced and aligned)ruler_70 wrote:So i took the car out on the highway again and realized it wasn't gear related afterall.panic-mechanic wrote:Yeah that kind of RPM and trying to pull under full load is not healthy and could cause a vibration. 4 Cyl motors don't like that kind of thing much.
It seems that almost every GTI and R has this at some point.
Ex: 2016 Golf 7 GTI
Ex: 2016 Golf 7 GTI
That's not nice.
- Ghostfacekilla
- Car Model: Golf GTi 7.5
Thats kak bra. Vibration is a difficult thing to live with if this is your daily drive.
All that tech and money and car still vibrating like a MK2
“It is not by muscle, speed, or physical dexterity that great things are achieved, but by reflection, force of character, and judgment”
CURRENT: GTI MK 7.5
EX: E90 LCI 320d Msport
EX: F20 118i Msport
EX: Polo 1.6 TDI 6R
EX: Polo 1.9 TDI 9n Sportline
PROJECT: MK2 GTI Jumbo
CURRENT: GTI MK 7.5
EX: F20 118i Msport
EX: Polo 1.6 TDI 6R
- ruler_70
- Colonel
Spoke to the dealer, they've asked me to bring the car in to sort out.
Ex: 2016 Golf 7 GTI
Ex: 2016 Golf 7 GTI
- Unobeat
- Car Model: Uno, Auris, CX-5
Hopefully they sort out the issue.ruler_70 wrote:Spoke to the dealer, they've asked me to bring the car in to sort out.
- Le Clue
- Membership No: 1458
What tyres are fitted?
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- Ghostfacekilla
Gud Luck
CURRENT: GTI MK 7.5
EX: F20 118i Msport
EX: Polo 1.6 TDI 6R
CURRENT: GTI MK 7.5
EX: F20 118i Msport
EX: Polo 1.6 TDI 6R
- ruler_70
- Colonel
It's got Pirelli Pzero's.Le Clue wrote:What tyres are fitted?
Ex: 2016 Golf 7 GTI
Ex: 2016 Golf 7 GTI
- Le Clue
Could be faulty tyres...ruler_70 wrote:It's got Pirelli Pzero's.Le Clue wrote:What tyres are fitted?
Previous Rides:
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- MaX
Mine fitted with same rubber and I am 90% sure its the tire. I just have too much tread left to take-off and throw away. Car is chowing rubber pretty quick so will just ride it out.Le Clue wrote:Could be faulty tyres...ruler_70 wrote:It's got Pirelli Pzero's.Le Clue wrote:What tyres are fitted?
- ruler_70
- Colonel
Re: Golf 7 GTI Vibration - Problem fixed
Just giving a bit of feedback on this issue, as the problem has been solved
So I took the car back the very next day, car was sent to a tyre shop (I took the car to the tyre shop myself) for balancing, as we suspected that this was the problem.
When the tyres were placed in the machine for balancing, they were all balanced correctly, however immediately you could see that the tyres were out of round (flat spotted).
The tyre shop notified the dealership and within an hour they called me to let me know that they had ordered new wheels for my car.
The wheels arrived and were fitted this morning and I am very glad to report that the problem is fixed and all vibrations are gone
Epic after sales service from the dealership as well
Ex: 2016 Golf 7 GTI
Ex: 2016 Golf 7 GTI
- Unobeat
- francois_gti
- Car Model: RS Mk5 Gti (Manual)
- Membership No: 3041
Great news!
Current: Mk5 Gti
Ex: Audi A3 1.8T
Ex: Citi Life 1.6i
Ex: Citi 1.6
Ex: Cti 1.8i
Ex: Audi A3 1.8T
Ex: Citi Life 1.6i
Ex: Citi 1.6
Ex: Cti 1.8i
- MaX
Excellent news. My SO cut a tire this weekend on a pothole so cant wait to fit new tires. Definitely not replacing with Pirelli!ruler_70 wrote:Just giving a bit of feedback on this issue, as the problem has been solved
- ruler_70
- Colonel
I kid you not, it doesn't even feel like the same car!MaX wrote:Excellent news. My SO cut a tire this weekend on a pothole so cant wait to fit new tires. Definitely not replacing with Pirelli!
You'll love how smooth it is once you have the new tyres on!
Ex: 2016 Golf 7 GTI
Ex: 2016 Golf 7 GTI
- Le Clue
ruler_70 wrote:I kid you not, it doesn't even feel like the same car!MaX wrote:Excellent news. My SO cut a tire this weekend on a pothole so cant wait to fit new tires. Definitely not replacing with Pirelli!
mmmm, maybe the Pirelli's don't take too kind to sitting on a boat for 4 months....
Previous Rides:
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
GOLF 7.5 GTi has it bad...
I went through these motions as well. My car is brand new and has been doing this since I got it. I fought with the dealership about this and they have eventually replaced the tyres 4 months in.
I can ttell you how many times the wheels have been balanced, alignment checked rims and tyres checked for out of round and nothing.
This did not resolve the problem on my car. Its still shaking the seats.
- ruler_70
- Colonel
Very sorry to hear that you're experiencing this problem.MarkusB wrote: ↑Mon Dec 10, 2018 2:51 pm GOLF 7.5 GTi has it bad...
I should mention that the dealership did not just replace my tyres, they gave me brand new rims and tyres and the problem was gone immediately.
Around 3 months ago I upgraded to the Golf 7.5 GTI and it is as smooth as silk, so it should definitely not be doing this.
Maybe try and see if you can get new rims from the dealership as well.
Ex: 2016 Golf 7 GTI
Ex: 2016 Golf 7 GTI
- AshTDi
- Membership No: 1823
I'm currently experiencing the same sort of vibration. I have Pirelli P1s on. Can't wait till the tread is low and I can finally change these crappy tyres!
Sent from my WAS-LX1 using Tapatalk
Spinning is not Winning
2014 Golf VII GTI
Viper Performance turboback, VWR R600 cold air intake
179kw 398nm
2008 Mazda 2 (the green goblin) - Ex
2008 Polo 1.9TDi Highline 96kw - Ex
Seat Sport FMIC, PD 160 Intake, K&N Filter, 63mm Freeflow exhaust, Mufflerectomy, Decat, 63mm Downpipe, EGR Delete, CPI Stage 2, Launch control, Full house exterior xenons
2005 Polo 1.9TDi 74kw - Ex
Stage 1 , Decat - VTec Auto
2014 Golf VII GTI
179kw 398nm
Thanks but it's definitely not the rims either. I took it to a rim repairs company who checked it for me with Lazer equipment. Both the rims and the new tyres checks out 100%
They're also flabbergasted. I made an appointment with vw tomorrow and th GM has a few plausible ideas. Disks, shocks, CV joints coil Springs. So let's weet of that bears any fruit. Will post the saga as it goes for anyone else who is batting with a nasty vibration.
