My 16v build, continued
Re: My 16v build, continued
Post by panic-mechanic » Fri Oct 06, 2017 1:39 pm
That seal you should only replace with OE.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
ob wan
Car Model: MK1 2.0 16vT
Post by ob wan » Sat Oct 07, 2017 12:24 pm
ok so the flooded dizzy wasn't the problem of the crazy rev counter...
after many double richelieu's and coke zero's, i unplugged the water temp sender for the gauge and voila.... no water temp but rev counter is normal...
hope this helps others in the future
05 G5 Gti (ex)
97 LSvtec (ex)
05 Ford Ranger 4.0 V6
Mk1 velo 2.0 16v...Turbo
ob wan
05 G5 Gti (ex)
97 LSvtec (ex)
PapaJo
Post by PapaJo » Sat Oct 07, 2017 8:14 pm
ob wan wrote:ok so the flooded dizzy wasn't the problem of the crazy rev counter...
And a double post
Was it the 4 pin temp sensor or two pin one?
ob wan
Post by ob wan » Mon Oct 09, 2017 3:07 pm
whoops....
the four pin one, but i spoke too soon, the rev counter is still acting crazy, it's running directly off the brown wire which is rpm output on the spits, it's as if it gets spiked....
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Mon Oct 09, 2017 3:29 pm
can anyone point in the right direction, i need to remove the coil neg resitor in the cluster....
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Mon Oct 09, 2017 3:59 pm
ob wan wrote:can anyone point in the right direction, i need to remove the coil neg resitor in the cluster....
turns out the velociti doesn't have one....
gan maar rondkrap by die coil....
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Mon Oct 09, 2017 4:15 pm
sorry guys, i feel like a complete twat, there was a couple of posts back something regarding the oil pressure light staying on if the rev counter doesn't work (panic still advised) and i never insulated the wire, which was now earthing against the fan causing the fan to randomly come on and the rev counter to go crazy, fixed it now......
hehehehe
05 G5 Gti (ex)
97 LSvtec (ex)
Vw 8v kid
Car Model: Mk1
Post by Vw 8v kid » Mon Oct 16, 2017 6:30 pm
Sorry to change the subject but I noticed you also running air con...was just wondering how you managed to fit the intercooler and the aircon condenser and radiator all in ? Do you mind posting some photos ? Thanks man! Hope she’s running strong!
Vw Mk1
2l :driving:
ob wan
Post by ob wan » Tue Oct 17, 2017 2:53 pm
Vw 8v kid wrote:Sorry to change the subject but I noticed you also running air con...was just wondering how you managed to fit the intercooler and the aircon condenser and radiator all in ? Do you mind posting some photos ? Thanks man! Hope she’s running strong!
yep "was" running aircon until one of the pipes broke, but it was really easy, the aircon pump was way down at the bottom below the alternator when it was originally a 1.4, so i just used the same bracket and made a mount for the alternator on top of it
the intercooler sits down low in the front bumper and doesn't come close to the condensor, it's a freelander tdi cooler... will check in my album and post some pix of that
this was ofcourse before i did the serpentine belt conversion, when i have all the brackets i'll put the ac back in.... just for when the wife drives the car, which in all honesty never happens...
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Tue Oct 17, 2017 2:55 pm
doing some baking today.... smells great
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Tue Oct 17, 2017 3:05 pm
first did the front then all 4...
now for the fun part, check the size of the tyre.... looks like a blues rim, right...?
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Tue Oct 17, 2017 3:09 pm
my set of 16's, bridgestone potenza's, still need to find 4x100 rims for these... :lol:
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Tue Oct 17, 2017 3:13 pm
oh and just to show the sleeper look with the 15's and dunlop semi's on( which i presume is street legal..):
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Wed Oct 18, 2017 1:41 pm
busy with a new oil catch tank, getting the hang of this ally welding
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Wed Oct 25, 2017 3:08 pm
built the hot side this morning... i LUUUUV welding aluminium!!!!
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Wed Oct 25, 2017 3:11 pm
ob wan wrote:busy with a new oil catch tank, getting the hang of this ally welding
well, had to use this for another project as a cuzzy needed it urgently.... so will post some pix of the new one once i started with it
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Thu Feb 22, 2018 5:00 pm
update:
my fpr decided to retire, got a new one and all is back to normal, until i disintegrated the leftside inner cv, so i upgraded to 100mm inners and outers, complete kit with cv cups, was a bit of a mission to install....
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Thu Feb 22, 2018 5:10 pm
aftermath of the cv..
stripped the box and welded it
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Sun Feb 25, 2018 11:07 am
Good morning peeps!
question, if you had damage to a piston due to too much boost and lean condition, would all 4 cylinder still have equal compression? i may have been naughty with the boost and now i have a missfire in boost, but all 4 cylinder shows an equal 8 bar across the range...
05 G5 Gti (ex)
97 LSvtec (ex)
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner » Sun Feb 25, 2018 1:39 pm
ob wan wrote:Good morning peeps!
Check the plugs first. Also do a cylinder leakage test. (Google this and how to make a tool to do the test)
The piston killer is actually a range of things.
The porcelain on the spark plug can bearing off from detonation and damage the piston. The lean mixture can burn and melt the pistons and also the sleeves. There are a few others that I can't think of now, but what it boils down to is the head must come off to properly ascertain the extent of the damage.
Even if once head is off and it all is ok, you won't be losing out because you will then know that the moving parts are all ok.
Donavan
Post by Donavan » Mon Feb 26, 2018 10:46 am
more likely to be a plug by the sound of your description
Audi A3 1.8t 20V
http://www.vwclub.co.za/phpbb3/viewtopi ... 11&t=33370
ob wan
Post by ob wan » Tue Feb 27, 2018 2:28 pm
noooo i only have to loosen the headbolts then it's off....
well rather safe than sorry....
thanks for the input guys, will post pics once i have it off
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Tue Feb 27, 2018 4:08 pm
oh happy days it was just a head gasket.... explains the 1bar drop between cyl 2&3...
after a little bit of carb cleaner, the pistons look brand spanking new, no pin marks or any signs of melting
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Tue Feb 27, 2018 4:09 pm
respek! for nural
05 G5 Gti (ex)
97 LSvtec (ex)
