My 16v build, continued
ob wan
Car Model: MK1 2.0 16vT
Re: My 16v build, continued
Post by ob wan » Fri Dec 02, 2016 1:27 pm
better pic
05 G5 Gti (ex)
97 LSvtec (ex)
05 Ford Ranger 4.0 V6
Mk1 velo 2.0 16v...Turbo
BdtDSG
Post by BdtDSG » Fri Dec 02, 2016 1:40 pm
Nice...
ob wan
Post by ob wan » Sat Dec 03, 2016 6:43 am
clutch will be going in this morning....
05 G5 Gti (ex)
97 LSvtec (ex)
PapaJo
Post by PapaJo » Sat Dec 03, 2016 7:16 am
Nice mod.
Did you get the pressre plate balanced?
ob wan
Post by ob wan » Sat Dec 03, 2016 1:32 pm
papajo, didn't balance it, but the clutch travel is a lot less now, being that the pressure plate face is now further away from the backing plate, so it has the same symptoms as the push rod being shortened, so in conclusion, the clutch doesn't release, so I modified the shoe pushing the release bearing to kick in earlier by changing the angle, still no clutch, so I put the original lever and shoe back in and tensioned the cable ALOT, but still no clutch....
anyone that has done a dual diaphragm had to do any other mods?
the clutch is also very noisy, probably had to tack the diaphragms together coz I can hear them squeaking... but my main concern now is getting g the clutch to disengage :bang: :bang: :bang:
I so badly wanted to do Zwartkops tomorrow :(
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Sat Dec 03, 2016 1:37 pm
or can someone please post a pic of a double diaphragm pressure plate, I just need to see what I did otherwise, please
05 G5 Gti (ex)
97 LSvtec (ex)
BdtDSG
Post by BdtDSG » Sat Dec 03, 2016 9:16 pm
Hey Obwan, jou broer verjaar vandag
PapaJo
Post by PapaJo » Sat Dec 03, 2016 10:54 pm
Here is some info from a post on this forum.
viewtopic.php?f=94&t=129129
Read this on formulafrictions site
http://www.formulafriction.co.za/produc ... ch-masters
ob wan
Post by ob wan » Sun Dec 04, 2016 9:20 am
ok I think I've figured it out, the thickness of both diaphragms, when on top of each other, must be the same thickness of only one
so the bottom one's outer diameter must be reduced to so it fits inside of the top one and not increase the height...
ps. you need fuggin massive leg muscles to step on the clutch now.... don't think it's worth it on a daily.... unless I cut out some of the clutch fingers to make it a little less stiff
05 G5 Gti (ex)
97 LSvtec (ex)
PapaJo
Post by PapaJo » Sun Dec 04, 2016 10:11 am
ob wan wrote:ok I think I've figured it out, the thickness of both diaphragms, when on top of each other, must be the same thickness of only one
Correct ob wan. The thickness have to be the sameas the single one. Not worth it for a daily. If it was a hydro clutch setup, it may gave been not that hard on your leg. Cable and thrust bearing will not last and also the part where it pulls through the firewall.
If going for double diapraghm, it is recommended to increase to a maximum of 50% over stock.
BlueBlob
Post by BlueBlob » Tue Dec 06, 2016 10:33 am
Ah. Sorry, that was my bad.
But as for the stiffness, you princesses need to harden up. I drove mine (two of them) daily like that for years.
Ok the one was hydraulic, but still. :lol:
Abnormal
Membership No: 848
Post by Abnormal » Tue Dec 06, 2016 10:47 am
had the double diaphragm on a cable clutch.
its does not feel that hard when you are driving it.
But later you start to wonder why you have knee pains!!!
\Oo) \ _w_ / (oO/
ob wan
Post by ob wan » Wed Dec 07, 2016 2:19 pm
Abnormal wrote:had the double diaphragm on a cable clutch.
or need a knee replacement....
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Wed Dec 07, 2016 2:23 pm
anyhow, put the std pressure plate back in with an almost new std clutch plate (thanks Rinus) and all is well now, had to decrease the boost a bit to keep from slipping, 0.5bar to be exact, but it will have to do for now.... :-( no more making clouds for my little one....
next year i'll focus on cable shifting the [email protected] out of that little golf....
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Wed Dec 07, 2016 2:24 pm
anyhow, put the std pressure plate back in with an almost new std clutch plate (thanks Rinus) and all is well now, had to decrease the boost a bit to keep from slipping, 0.5bar to be exact, but it will have to do for now.... :-( no more making clouds for my little one, oh the joy on her face when we make clouds....
05 G5 Gti (ex)
97 LSvtec (ex)
Abnormal
Membership No: 848
Post by Abnormal » Wed Dec 07, 2016 2:25 pm
You will also pretty much have to pull over and wait until traffic clears if you find yourself in a traffic jam. It's a biatch with a copper clutch.
\Oo) \ _w_ / (oO/
ob wan
Post by ob wan » Fri Dec 09, 2016 12:39 pm
built myself a turbo intake, what youz think?
still need to tidy the welds up the painting it black with the area surrounding the lettering to be polished
05 G5 Gti (ex)
97 LSvtec (ex)
PapaJo
Post by PapaJo » Fri Dec 09, 2016 4:04 pm
Why so many welds? Seen guys cutting and joining with only one cut behind the injectors. Are there any tricks inside the plenum?
ob wan
Post by ob wan » Sat Dec 10, 2016 9:40 am
couldn't find any pipe matching the ports so I had to cut a round tube in half and insert a 10mm piece so that it fits snug to the flange, so it's smooth on the inside
no tricks yet, busy researching on flow inside a turbo manifold, plenum size and runner length, then i'll have it all machined and build a lekker one
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Sat Dec 10, 2016 10:13 am
I'm soooo chuffed, getting the hang of this ally welding now, still need a lot of practise though
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan » Thu Jan 05, 2017 4:41 pm
little present from me to me
05 G5 Gti (ex)
97 LSvtec (ex)
PapaJo
Post by PapaJo » Fri Jan 06, 2017 4:17 pm
ob wan wrote:little present from me to me
Very nice present you got there! :drool: Who made this for you and price if you don't mind sharing.
ob wan
Post by ob wan » Tue Jan 10, 2017 6:08 pm
got it 2nd hand from a buddy, had it repacked in vanderhoff road for R400, no more clutch slipping, even at 1.3 bar...
05 G5 Gti (ex)
97 LSvtec (ex)
PapaJo
Post by PapaJo » Tue Jan 10, 2017 8:06 pm
ob wan wrote:got it 2nd hand from a buddy, had it repacked in vanderhoff road for R400, no more clutch slipping, even at 1.3 bar...
Smoking the wheels big time, for sure!!
Great stuff!!
Did you fit this to a standard 16V pressure plate?
Post by panic-mechanic » Wed Jan 11, 2017 7:25 am
I never had luck with solid centre clutch plates. Always tore the centre section out.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
