Polo GTI 1.8T Smokes On Idle When Cold
Herschel
Car Make: Toyota & VW
Car Model: RXI & CiTi Golf
Post by Herschel » Mon Dec 08, 2014 11:39 am
My wife's Polo GTI smokes when the car idles & when it's cold.It's white smoke,so it's oil & you can smell it.As you the drive the car the smoking stops.
Could it be turbo seals that's messed up?
2011 Golf MK6 GTI DSG
Factory Stock.....For Now
05' 2E 2.0i 8V 276Estas Cam CiTi Golf
97kw & 176nm (JVS Tuning)
pyro-zn
Car Model: Golf 6 GTI K04
Membership No: 2072
Re: Polo GTI 1.8T Smokes On Idle When Cold
Post by pyro-zn » Mon Dec 08, 2014 1:31 pm
On cold? 100% sure?
Current: '12 TR Golf Vi GTi DSG ::: Revo3 - thread
Ex: '13 Polo 1.4 Comfortline ::: PanoRoof | JOM Bluelines | 17" A-Line Racers | 17" VW Boavista's
by Borbet - thread
Uncle Nunda
Car Model: Scirocco R
Membership No: 1489
Post by Uncle Nunda » Mon Dec 08, 2014 1:34 pm
look like someone deleted my comments here hmmmm
like i said before Larry also had this issue and it turned out to be the turbo seals also if something has cracked on the manifold
as these cars are prone for that
Herschel
Post by Herschel » Mon Dec 08, 2014 1:37 pm
pyro-zn wrote:On cold? 100% sure?
Yes or if the car idles too long
Herschel
Post by Herschel » Mon Dec 08, 2014 1:38 pm
Uncle Nunda wrote:look like someone deleted my comments here hmmmm
:thumbup:
shan00ble
Post by shan00ble » Sat Dec 13, 2014 9:00 pm
As far as I know white smoke is water or coolant. Blueish smoke is oil usually.
Herschel
Post by Herschel » Mon Dec 15, 2014 10:46 pm
Won't be valve stem seals, otherwise it would smoke everytime a person lifts your foot from the petrol.
Thanks for all the comments
Kevin vw 1.8t
Post by Kevin vw 1.8t » Sun Oct 02, 2016 9:02 pm
Hi guys I'm new here I have a polo gti 9n about three months back I put a new turbo in car drove fine no smoking until two weeks ago car started smoking again only on idle drive the car no smoke sit in traffic smokes up car has a downpipe software n no other mods
Herschel
Post by Herschel » Sun Oct 02, 2016 9:47 pm
Change the PRV valve, changed that on our car & the smoking stopped
Kevin vw 1.8t
Post by Kevin vw 1.8t » Sun Oct 02, 2016 10:38 pm
Any idea where it's fits
Herschel
Post by Herschel » Sun Oct 02, 2016 10:40 pm
It sits on the top right hand corner of the valve cover on the turbo inlet pipe , it looks like a hockey puck.
Kevin vw 1.8t
Post by Kevin vw 1.8t » Sun Oct 02, 2016 10:57 pm
When you change yours did it stop smoking straight away
Herschel
Post by Herschel » Sun Oct 02, 2016 11:05 pm
Yes
Herschel
Post by Herschel » Sun Oct 02, 2016 11:06 pm
& it's not expensive +-R350
Kevin vw 1.8t
Post by Kevin vw 1.8t » Sun Oct 02, 2016 11:17 pm
Thank you will buy 1 2m n try it
Kevin vw 1.8t
Post by Kevin vw 1.8t » Mon Oct 03, 2016 6:35 pm
I put a new pvc valve car still smokes my old pcv had sum oil in but now so bad will a faulty coolant temp switch n thermostat cause the car to smoke
Post by panic-mechanic » Mon Oct 03, 2016 7:27 pm
the short answer is yes it could be the turbo.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
Kevin vw 1.8t
Post by Kevin vw 1.8t » Mon Oct 03, 2016 10:06 pm
Turbo is like 3 months old very strange
Herschel
Post by Herschel » Mon Oct 03, 2016 10:27 pm
Did you replace this?
Kevin vw 1.8t
Post by Kevin vw 1.8t » Tue Oct 04, 2016 8:49 am
yes replace that but still smokes but + I open up the intercooler pipes no oil
Silver Srfer
Car Model: Polony GTi
Post by Silver Srfer » Thu Dec 08, 2016 9:17 am
Sorry for the hijack, but I seem to have the same issue.
When the car is cold, there is no smoke, but as soon as I'm standing too long in traffic, it starts smoking quite a bit.
Not sure where to start? PVC, Turbo, Cooler?
Runx RSi 2ZZ | Energy Suspension | UniQ+ | Competition Clutch | MWR | HKS | ProFit |BLOX |
9N3 GTi | 76mm DP |Intake | FMIC
JasonCPT
Car Model: A4 1.8T
Post by JasonCPT » Thu Dec 08, 2016 9:22 am
Silver Srfer wrote:Sorry for the hijack, but I seem to have the same issue.
Check PCV, mine did the same and went away when I changed my PCV (it also had a farkoff big hole in it).
I don't have any smoke now besides a blue puff on coldstart startup, which is turbo.
2004 B6 Audi A4 1.8T - Atlas Grey
FK Automotive | Forge | Jaylan Performance | Zeetech Customs | VAGAS | Ratchet Garage
Silver Srfer
Post by Silver Srfer » Thu Dec 08, 2016 9:28 am
Thanks man, will check it out this weekend and replace it
JasonCPT
Car Model: A4 1.8T
Post by JasonCPT » Thu Dec 08, 2016 9:30 am
Its really cheap too, got the parts from GW.
P1LAYA-ZN
Car Make: Audi, VW and Toyota
Car Model: S3 8L 20VT & Mk 1 Jetta GLi
Post by P1LAYA-ZN » Thu Dec 08, 2016 1:57 pm
Good day gents,
I also have a similar issue on my A3 1.8T 8L. Car only smokes on idle when warm, eg. sitting at a robo, then a puff of smoke when taking off, but under normal driving, no smoke and no problems with boost either. I did notice a split in the hose from the Hockey puck, then another hose also split. I think it could be related to the PCV system but I had changed the PCV last year when I first started observing this smoking. Could it be the PRV/Hockey puck valve that is causing this smoking issue ? If so, how can you test this valve ? Also, if it is PCV related, is fitting a catch can / PCV delete the solution to the problem ? Are there kits available for the 1.8T's ?
Any advice will be greatly appreciated.
#Builtnotbought
