Golf 6 Gti hard starting
Phil
Post by Phil » Sun Oct 12, 2014 6:48 am
Hi guys.I have a problem with my Gti.Vehicle battles to start up usually while still warm.Cranks fine but battles to fire-up takes 2 to 3 attempts sometimes having to floor accelerator.No errors come up.Vw checked it out for me and said the only error that came up was a cam sensor position error,but what I find strange is that the error only appeared once a few days ago but the problem is now daily.Any ideas?Regards
Titleists
Philosopher STIG
Membership No: 1520
Re: Golf 6 Gti hard starting
Post by Titleists » Sun Oct 12, 2014 8:10 am
The chain tensioner might be on the way out. Take it back asap before the engine fails to start completely.
Sent from my VCDS
VCDS changes done by me for a minimal fee
My ex rides:
2013 LHD Scirocco R
2011 Golf 6 GTI
TimeShifter
Car Model: 2012 Mk6 GTi
Post by TimeShifter » Sun Oct 12, 2014 8:49 am
Titleists wrote:The chain tensioner might be on the way out. Take it back asap before the engine fails to start completely.
Sent from my VCDS
Do this like in yesterday!!!
2012 VW Golf Mk6 GTi
Post by ruan9n » Sun Oct 12, 2014 10:15 pm
Camshaft positioning sensor.... is there oil seepage coming from it? Take it out and clean it then reinstall and see what happens! It's a common problem across the world on 2.0tsi's, oil seeps past its little green gasket and into the sensor itself.
hernandez
Car Model: X5M, M5, TOUAREG, CORSA UTE
Membership No: 1491
Post by hernandez » Tue Oct 14, 2014 3:06 am
cam chain jumped 1 tooth, thus the fault and the hard start. 1 more tooth and engine is game over. Have seen this plenty times. Tensioner failure allows enough slack to jump. Check urgently
Current: BMW X5M, BMW M5TT, TOUAREG, CORSA UTE
Ex: 4x C63 (2XSupercharged) , 1x Bmw M5 V8 biturbo, 2x G5 GTI k04's, 1x R32 G5, 1x G6 R, 1x Amarok DC, 1x Touareg, 1x Bmw X5 v8, 1x audi A3 2.0T, 1x audi S3, 1x audi TTS.
Yes, I have an addiction.
Solo786
Autowerks
Car Make: Porsche,BMW,VW
Membership No: 1251
Post by Solo786 » Tue Oct 14, 2014 11:18 am
rather have it towed in rather than risk driving it
MERCEDES|BMW|PORSCHE|AUDI|VW|FORD
Respect my AuthoriTaah!
Check out Autowerks on Fb
Check out AutoSpa on Fb
Post by ruan9n » Tue Oct 14, 2014 11:30 am
hernandez wrote:cam chain jumped 1 tooth, thus the fault and the hard start. 1 more tooth and engine is game over. Have seen this plenty times. Tensioner failure allows enough slack to jump. Check urgently
Tata hasie :hi:
K.J
Car Model: MK6 GTI
Post by K.J » Tue Oct 14, 2014 12:12 pm
Is there a definite way to confirm this?
I have similar problem, but VW says they can't find anything wrong..
So it's a back and forth saga with nothing getting done, and OP and me would be in similar situation...
We can't wait for it to break before anything gets done
Titleists
Philosopher STIG
Membership No: 1520
Post by Titleists » Tue Oct 14, 2014 12:15 pm
K.J wrote:Is there a definite way to confirm this?
Yes, open up the motor.
My ex rides:
2013 LHD Scirocco R
2011 Golf 6 GTI
K.J
Car Model: MK6 GTI
Post by K.J » Tue Oct 14, 2014 1:00 pm
Is there a way to convince VW to do this?
Titleists
Philosopher STIG
Membership No: 1520
Post by Titleists » Tue Oct 14, 2014 1:19 pm
K.J wrote:Is there a way to convince VW to do this?
Yes, you have to pay them. Unfortunately, they are not interested in doing anything before something breaks even when they know it's going to break.
My ex rides:
2013 LHD Scirocco R
2011 Golf 6 GTI
Phil
Post by Phil » Wed Oct 15, 2014 3:20 am
Hi,what doesn't make sense to me is the fact that if I try and start the vehicle as soon as I have stopped and turned it off ,it starts with no hassle.It only occurs when the vehicle has stood for a few minutes.Would this still relate back to the chain having jumped a tooth?Would I not notice any deficiency while driving if that was the case?
Abnormal
Membership No: 848
Post by Abnormal » Wed Oct 15, 2014 6:06 am
The cam tensioner works with oil pressure.
Letting it stand for store time means the oil pressure needs to build up before it can tension the chain again.
\Oo) \ _w_ / (oO/
hernandez
Membership No: 1491
Post by hernandez » Wed Oct 15, 2014 5:56 pm
Abnormal wrote:The cam tensioner works with oil pressure.
revised part has spring now
K.J
Car Model: MK6 GTI
Post by K.J » Mon Oct 20, 2014 1:00 pm
What about possibly the hpfp?
Is supposed to prime when drivers door is opened, but i notice mines only starts when key is in ignition and in on position.
Phil, try putting key in on position for a few seconds and then start, and if it's better
Phil
Post by Phil » Sat Apr 11, 2015 7:25 am
Problem sorted!
Belix
Car Model: GTi 6, Jetta CLX MK2
Post by Belix » Sat Apr 11, 2015 2:17 pm
so what was it the tensioner after all?
Anyone need VCDS coding?
My ride thread: Reflex Silver 2010 MK6 Gti
The old girl: Red 1990 Jetta 2 GLX 3 SPD Auto
Wisey
Post by Wisey » Thu Feb 08, 2018 5:47 am
No guys
its a common issue on this engines...... the most failing parts could be fuel module or tank fuel pump ....
From my experience i ve got MK VI- GTi and MK VI-R
Belix
Post by Belix » Thu Feb 08, 2018 8:12 am
there are so many supposedly common issues, it's getting hard to keep track of them all...
Post by panic-mechanic » Thu Feb 08, 2018 9:29 am
Seeing wisey is new and probably trying to sell something we can probably expect at least 50 old posts resurected relating to anythin golf 6 and 7.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
RoyG6R
Car Model: mk6 Golf R
Post by RoyG6R » Sat Mar 03, 2018 8:41 pm
Hi Guys! I have recently got my Golf 6 R and its running well and smooth, just wanted to know why is it swings sometimes and the you gotta gas it and it starts...but doesn't occur all the time. I have asked VW as to whats up with this.
2013 Golf 6R
2014 CLA AMG
1989 MK1 GTI 2.0l 8v
RB35 Nissan Skyline
