So I have a Polo GTI 1.8T (BJX). The cam belt snapped recently so I redone everything. But now it's idling very rough and like got a misfire. I took it to VW to get logged and the following error codes came up:
16420 P0036 035 - O2 SENSOR HEATER CONTR. CIRC (BANK1(1)SENSOR 2) - static
17748 P1340 035 - CAMSHAFT POS./CRANKSHAFT POS SENSOR- INCORRECT ALLOCATION - static
16684 P0300 035 - RANDOM/MULTIPLE CYLINDER MISFIRE DETECTED - static
16685 P0301 035 - CYL.1 MISFIRE DETECTED - static
Can someone please explain to me what "cam/crank pos sensor incorrect allocation" means?
And which lambda sensor should i replace? and will the cam/crank sensor cause a misfire?
Thanks guys...happy shifting
Cam / crank pos sensor - incorrect allocation
- Car Make: Polo
- Car Model: GTI
- Car Make: SEAT
- Membership No: 478
Re: Cam / crank pos sensor - incorrect allocation
Are you sure you got the cam timing and engine timing correct?Hitesh25 wrote:Hi guys
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
Howzit .had the sam problem as you .sent it to vw they changed the crank gear and cam gear .car is perfect now
- Taz0
- Car Model: Polo 9N3 2.slow
- Membership No: 1925
Get the cam gear checked...
The tooth that guides the gear on the cam shaft tends to break with a cambelt snap
Mk1 Citi golf
Mk5 R32
Mk4 golf 3.6 4motion
Mk5 R32
- Car Make: SEAT
Have a look here - http://wiki.ross-tech.com/wiki/index.ph ... 340/004928Hitesh25 wrote:Hi guys
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- Car Make: Polo
- Car Model: GTI
Thanks guys!!
Hi. I have the same issue and my diagnostic shows that my timing is between 7 to 7.5°BTDC. Could this still be the Cam/Crank pulley if the timing is spot on????
- Registered for: 3 years 7 months
Cam timing is not in the correct position. Crank sensor and cam position sensor not in the correct allocation position.
Sent from my SM-G988B using Tapatalk
