Golf 5 GTI issues. Please Help
Sinbad
Car Make: Mercedes
Car Model: R170 AMG Hairdryer
Membership No: 1152
Re: Golf 5 GTI issues. Please Help
Post by Sinbad » Thu Jan 22, 2015 11:25 am
What dtcs are stored?
FRANNA
Post by FRANNA » Thu Jan 22, 2015 8:16 pm
have you replaced the rear pump in the tank??
if not do that
[email protected]!0
Post by [email protected]!0 » Fri Jan 05, 2018 9:02 pm
whats a quick fix for the cracked hpfp sensor? i replaced the thrust and fuel rail sensor (r2.4k later) now the top sensor is stuffed...:(
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner » Sat Jan 06, 2018 8:00 am
[email protected]!0 wrote:whats a quick fix for the cracked hpfp sensor? i replaced the thrust and fuel rail sensor (r2.4k later) now the top sensor is stuffed...:(
None
Put new
Camo
Car Model: White-G5 GTi
Post by Camo » Tue Jan 09, 2018 1:31 pm
It can be fix'd, very easy to do.
Mine also did the same after fitting the second HPFP just becoz of a cracked sensor. I was not gonna buy a complete HPFP just becoz of a sensor.
You would need to completely strip the black plastic from the top of the sensor, then solder the two pins to wires,..once done you would then have to trace and connect the two wires to the other end as per the plug. If you not gonna use after market plugs I would suggest that you give the connection or wire little bit slack to allow for HPFP to com off in future.
If you want I will help, I have a spare top sensor that I have already done.
