Was that at VW?aslam wrote:I did mine Oct 2012
I paid R4272 parts and labour incl.
The following parts were bought.
Part numbers:
Old part number for tensioner was 06H 109 467 AB (12-12-11 and earlier)
New part number for tensioner is 06K 109 467 K (13-12-11 and later)
Old part number for cover: 06H 109 210Q
New part number for cover: 06K 109 210
Sealant needed for sealing cover: D 174 003 A2
G6 gti timing chain tensioner issues
- Membership No: 1708
Re: G6 gti timing chain tensioner issues
- rodga
- Nazi Spelling Master
- Car Model: MKVI GTI
- Membership No: 1323
done through VW?aslam wrote:I did mine Oct 2012
Part numbers:
rodga's ride
'09 Generic XOR 125 - matte black - Daily Driver
rodga's ride
- Car Model: MK6 GTi
Yep.
Tavcor VW. Invoice at home.
- rodga
cool
rodga's ride
rodga's ride
So R1500 anywhere elseaslam wrote:Yep.
Sent from my Samsung Galaxy S5
- General
- Car Model: MKV .:R32
- Membership No: 1227
That's not bad aslam.
So will this reduce the risk or cancel out?
MKV Golf .:R32
Project :83' MK GTI aka "The Phantom"
BMW 130i
MK VI GTI DSG
MKV Golf .:R32
BMW 130i
MK VI GTI DSG
- Belix
- Car Model: Passat B8
Nah, have heard of same story with new version tensioner, so reduce, not cancel
- General
LOL.Belix wrote:Nah, have heard of same story with new version tensioner, so reduce, not cancel
Lucky packet style. So if its not an issue wait for it. This is not cool.
MKV Golf .:R32
BMW 130i
MK VI GTI DSG
MKV Golf .:R32
BMW 130i
MK VI GTI DSG
Well, been running almost 2 years with this setup and no issue. And if you look at how that revised tensioner work then you can see what it does when oil level/pressure is low.De@n wrote:That's not bad aslam.
Also knowing I was going to keep the car, I took the plunge and did the replacement.
You will be fine with the revised tensioner, it fixes the flaw on the first one that causes it to fail and the chain to skip teeth.
The 2011+ cars have the revised tensioner. That revised tensioner is specifically designed not to fail like the original one.
You can have the tensioner changed, the part is R1200+- for the revised tensioner. There are special tools required though such as the one to hold the crankshaft.
It is a case of wear on the original tensioner, it is not random lucky packet style.
Same as the cam follower issue on the 5. It is caused by wear, eventually when it wears out completely you break stuff.
If you are really worried spend a couple thousand and replace it with the revised tensioner regardless of model year.
Balls wrote:You will be fine with the revised tensioner, it fixes the flaw on the first one that causes it to fail and the chain to skip teeth.
- General
Thank you.aslam wrote:Balls wrote:You will be fine with the revised tensioner, it fixes the flaw on the first one that causes it to fail and the chain to skip teeth.
I will take that plunge and do it if I decide to keep the car in the next 2 months.
MKV Golf .:R32
BMW 130i
MK VI GTI DSG
MKV Golf .:R32
BMW 130i
MK VI GTI DSG
- rodga
is it the one on the left in the pic u posted?Balls wrote:You will be fine with the revised tensioner, it fixes the flaw on the first one that causes it to fail and the chain to skip teeth.
rodga's ride
rodga's ride
Right
- rodga
u mean the one on the right??Balls wrote:Right
Sent from my SM-N900 using Tapatalk
rodga's ride
rodga's ride
Rightrodga wrote:u mean the one on the right??Balls wrote:Right
- Belix
Think I'll have mine changed next service. Asked last time and dealer said to leave it until it needs changing...
- Ettie70
- Car Model: Jetta mk6 2.0 tdi
If anyone is interested... I have a brand new revised tensioner and the crank pulley bolt for sale.. make me a offer... Im selling my car so wont be needed anymore
Sent from my GT-I9300 using Tapatalk
2011 BMW E90 LCI 330d Msport
2009 BMW E90 320d Msport
2013 Jetta 6 2.0TDi H/L - Revo 2
Magic Black 2010 Golf 6 GTI - Stealth Tuned Stage 2
Dove Grey 2007 1.8T Polo GTI - Revo Stage 2
2005 Silver Opel Corsa 1.6 Sport
- Belix
Balls wrote:Rightrodga wrote:u mean the one on the right??Balls wrote:Right
According to the part numbers on the top, the revised one would be the one on the left, no?aslam wrote: Part numbers:
Right
- Car Model: Edition35
The tensioner on the LEFT is the correct one. Ettie70 is selling this one!
Current: 2013 Golf 6 GTi ED35 DSG
ex: 2009 Golf 6 GTi DSG
ex: Runx Rsi
ex: Rxi 20v 14.98 msa
ex: Runx Rsi
- Major-General
- Registered for: 21 years 3 months
- Car Model: MK1
So according to the above if the motor was built( not car sold) in roughly 2012, they have the tensioners revised so no need to stressaslam wrote:I did mine Oct 2012
Part numbers:
New part number for tensioner is 06K 109 467 K (13-12-11 and later)Old part number for cover: 06H 109 210Q
Ex '02 Citi.Com 20VT K04
'80 MK1 L 2Dr 8V Throttles
Zubair Aka Boost Junkie
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
Very possible yes.Zubair wrote:So according to the above if the motor was built( not car sold) in roughly 2012, they have the tensioners revised so no need to stressaslam wrote:I did mine Oct 2012
Part numbers:
But I have the "suspect" 09 model, just thought I would try to reduce the risk of failure.
- Major-General
- Car Model: MK1
My motor was built in August 2012 (final spec, last batch D chassis numbers), and sold to me late 2012 with chassis number showing MY2013 on VW's system so hoping I am safe cause if my car doesn't have the revised parts, none has from the factory then.
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
Your warranty is still long to worry about this nowZubair wrote:My motor was built in August 2012 (final spec, last batch D chassis numbers), and sold to me late 2012 with chassis number showing MY2013 on VW's system so hoping I am safe cause if my car doesn't have the revised parts, none has from the factory then.
