What boost are ur guys 1.8T running Stage 1 or Stage 2
pluto
Re: What boost are ur guys 1.8T running Stage 1 or Stage 2
Post by pluto » Thu Nov 28, 2013 6:59 pm
270 whp and 400 wnm on a 1.8T with K04-23 , 1.5 bar for me ...In my Mk1 - FRC Dyno last week with 28 deg room temp and pump gas
Shiver me Wastegates
Frieling Racing Chip tuning
2013 TT-RS S Tronic
MK1 20VT BAM (Motronic ME 7.5 DBW)
Jueshen
Post by Jueshen » Sat Dec 07, 2013 1:25 pm
on unitronic website:
1.8T stage 2 on peak boost is 18 psi
which is 1.275 bar
so why the spike for some of us to 1.4...
http://www.unitronic-chipped.com/ecu-tu ... 009-stage2
I know in winter I spike 1.4
summer 1.3...
2003 Audi A4 Avant 1.9TDI
2015 Toyota Corolla D4D
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
Killerwatt
Car Model: S3
Post by Killerwatt » Sun Dec 08, 2013 7:56 am
1.4 vs 1.275 isnt a huge spike so no need to worry.
Basically it happens because your boost pid isnt tuned perfectly for your motor. Ideally you actual should meet requested and then not overshoot.
RPGTI
Car Model: '13 PGTI DSG
Post by RPGTI » Fri Feb 14, 2014 7:00 am
Since fitting the cupra cooler I just touch 1.3bar now so can only imagine that the old cooler was very congested either in the core or the piping but funny enough, less boost but it feels stronger.
'13 Flash Red Polo GTI
Ex.
'08 Flash Red Polo GTI
MickeyEngles
Car Model: Fiesta ST
Post by MickeyEngles » Fri Feb 14, 2014 11:10 am
FRC stage 1 boosting about 1.25bar which tapers down to about 1bar
Current : 2013 Ford Fiesta ST
Previous :
2004 Mitsubishi Lancer
2002 Audi A3 1.8T (136wkw 342nm)
2007 Citi golf 1.4 chico
jk
Post by jk » Fri Feb 14, 2014 11:13 am
REVO 1
No idea what boost im running
MouseGTI
Car Model: B7 20vT
Post by MouseGTI » Fri Feb 14, 2014 12:09 pm
Cpi...i think im at 1.3bar
sent with 153 flywheel killerwatts
White '07 Polo GTI 9n3 - Stock
Black '07 Polo GTI 9n3 - 113fkw 234nm stock -> 153kw 277nm chooned
Green '16 Kawasaki Z300
28kw 27nm @ 11k rpm :crazy:
Silver '07 Slowdi A4 B7 1.8t - w/ T3T4 powers
141kw 278nm w/ KO4-0015
FKn Coilovers : 76mm DP + zorst : 101mm zorst tips : FMIC : IE Coil Spacers : Moar IE stuff : Neuspeed Short Shifter : BFI Weighted Knob : Cupra Lip
Firestrm_ZA
Vice Chairman
Vice Chairman
Car Make: SEAT
Car Model: 2008 Leon Cupra
Membership No: 1906
Post by Firestrm_ZA » Fri Feb 14, 2014 12:12 pm
FRC Stage 2 - 1.4Bar boost
This is after I changed my intake, DV (havent taken it for a remap) before with a BMC intake and 007DV I was running 1.25Bar
da joker
Car Model: Mk3 VR6 Jetta
Post by da joker » Fri Feb 14, 2014 1:03 pm
if you guys are peaking at over a bar boost, do you guys run on a mix? as i would assume running 1.4 with without compensation on the fuel side, would lead to deternation. Just asking, as i had agu, BT setup, maped 0.9 low boost, and anything over i either used octain booster or avgas
Im not driving fast.....im flying low !!!
BT Mk4 Gti (Current)
Mk4 Gti (ex)
20v Rsi (ex)
20v Rxi (ex)
Golf 1 1.6i+vat (ex)
Golf 1 abf (ex)
1.3 tazz (ex)
328i droptop (ex)
Jetta Vr6 (ex)
83' porsche 944 (ex)
Golf 1 20v Turbo (ex)
Gsi 16vS (ex)
78' Rabbit stroker (ex)
325is evo2 (ex)
20v Quest (ex)
4E Turbo quest (ex)
1.6i Velocity (ex)
84 mk1 GTI 14.8 at Tarlton (ex)
16 sport Mk2 (ex)
RS2000 (ex)
16 Sport Mk2 (ex)
Breadroll
Car Model: A3 1.8T
Membership No: 1989
Post by Breadroll » Fri Feb 14, 2014 1:19 pm
da joker wrote:if you guys are peaking at over a bar boost, do you guys run on a mix? as i would assume running 1.4 with without compensation on the fuel side, would lead to deternation. Just asking, as i had agu, BT setup, maped 0.9 low boost, and anything over i either used octain booster or avgas
I was running 1.5bar boost on 95 with k04
Stompie
Boostleak Guru
Car Make: VW POLO
Car Model: 07' GTI 9n3
Membership No: 1843
Post by Stompie » Fri Feb 14, 2014 1:27 pm
Jip running 1.3bar boost on plain ol 95 pump no pinging or predetonation at all and very very little timing pull...like max -4deg now and then
BMW 120D E87
da joker
Post by da joker » Fri Feb 14, 2014 1:28 pm
Mk4 Gti (ex)
20v Rsi (ex)
20v Rxi (ex)
Golf 1 abf (ex)
1.3 tazz (ex)
328i droptop (ex)
Jetta Vr6 (ex)
Gsi 16vS (ex)
325is evo2 (ex)
20v Quest (ex)
4E Turbo quest (ex)
1.6i Velocity (ex)
16 sport Mk2 (ex)
RS2000 (ex)
16 Sport Mk2 (ex)
Smok3X
Car Make: SEAT
Car Model: LEON CUPRA 2.0 TFSi K04
Membership No: 3083
Post by Smok3X » Fri Feb 14, 2014 1:28 pm
Spike 1.3bar and hold 1.1bar on Revo Stage 1.
Car is stock (Hardware wise)
Logs show zero timing pull.
Leon CUPRA - 2.0TFSi K04--> Rides Thread
[email protected] Artz - Stock
[email protected] Artz - RevO 2+
Ibiza CUPRA - 1.8 20V - Hybrid Turbo-->Rides Thread
Revo:182KW and [email protected]
ABF Citi Golf - 2.0L 16V--->Rides Thread
FRC - 124KW and [email protected] Trix
1/4 Mile:14.61s
1ST Place - 4AF2 Margate 31st Oct 2010
Smok3X
Car Make: SEAT
Membership No: 3083
Post by Smok3X » Fri Feb 14, 2014 1:31 pm
1 bar boost on a big turbo is not the same as 1 bar boost on a small turbo.
Boost PRESSURE is not the same as air flow.
Think of it this way. A Truck tyre takes 2 bar of air when you fill the tyres... so does my bicycle! Which has more air? Its a measure of PRESSURE in the intake manifold. A BT car can make way more power with alot less boost.
1/4 Mile:14.61s
RPGTI
Post by RPGTI » Fri Feb 14, 2014 2:03 pm
So looking at it most stage 2 guys are sitting at 1.3bar boost
Ex.
MouseGTI
Car Model: B7 20vT
Post by MouseGTI » Fri Feb 14, 2014 2:17 pm
I dont know what stage i am.....lol
MouseGTI
Car Model: B7 20vT
Stage 1 i guess...
RPGTI
Post by RPGTI » Fri Feb 14, 2014 3:11 pm
MouseGTI wrote:Stage 1 i guess...
Yep with a few more hardware mods you will be able to upgrade the software :evil:
Ex.
MouseGTI
Car Model: B7 20vT
Post by MouseGTI » Fri Feb 14, 2014 3:17 pm
Im actually considering stopping where i am now...and then selling the polo during the year...and getting a 8P S3 sportback
RPGTI
Post by RPGTI » Sat Feb 15, 2014 7:47 am
Good choice bud, pricey for one with low mileage. I recon ill hold out till the facelift pgti comes if its a 1.8T that is.
Ex.
MouseGTI
Car Model: B7 20vT
Post by MouseGTI » Sat Feb 15, 2014 3:42 pm
RPGTI wrote:Good choice bud, pricey for one with low mileage. I recon ill hold out till the facelift pgti comes if its a 1.8T that is.
Yeah...im waiting for that also...it may be a option
teamx
Car Make: Honda
Car Model: FN2 Type R
Post by teamx » Sat Feb 15, 2014 5:52 pm
Peaking at 1.35 here.
Sent from my Xperia Z1
Fast and cheap won't be reliable, reliable and cheap won't be fast, fast and reliable won't be cheap.
Honda Civic Type R (FN2)
2007 SEAT Ibiza Cupra 1.8T
2006 Polo 2.0
2007 GTi (DSG)
OPClite
Post by OPClite » Mon Feb 17, 2014 11:07 pm
MouseGTI wrote:
icemanwp wrote:@My-gti what are u boosting, i knw Cpi does boost high. What power u making on the coast?
honestly at the moment i have no idea. i really havent time to go to CPI in months for anything. i'm in the process of getting a boost gauge fitted...then i'll check that and compare with what CPI has on my car....any numbers i say now will just be me grabbing numbers....i could quote from Torque Pro, but no idea on the accuracy. it gave me 1.3bar many many moons ago...could be changing software also in the year so who knows...
What software are you looking at changing to?
STEALTH TUNED Rocco TSi
STEALTH TUNED Fortuner 4x4 Auto
15 STEALTH TUNED Fiesta ST
08 STEALTH TUNED Polo GTi
182wkw/244whp 440nm
OPClite
Post by OPClite » Mon Feb 17, 2014 11:10 pm
icemanwp wrote:Thanks man, im still on the original Dv would the Forge 007 Dv help with this?
I will be selling my Forge 008 dv in the near future, so holla if you interested :hi:
182wkw/244whp 440nm
MouseGTI
Car Model: B7 20vT
Post by MouseGTI » Mon Feb 17, 2014 11:13 pm
The options are FRC and Stealth in CPT. Im not a big fan of Ferroli so Revo is out. Stealth is the closest to me
