1.8T maf signal too high
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Re: 1.8T maf signal too high
yeah i know, the element on your current maf is the same. So you could even buy a dead maf and swap the element over.
also if you look at the element in the housing it is placed at an angle already
read here that you guys are turnin the housing to a correct angle
think al long as housing is in a straight line all else is fine
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
any update?
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
- Car Model: mk1 G60 Turbo
Sadly no
Still trying to source a 3" Maf housing
G60 Turbo (in progress)
Hey budGizmo20VT wrote:k03s MAF Cap should be just over 220g/s and k04 is 292g/s cappedGplay wrote:Sadly no
Maf signal to high would still result in a faulty Airflow sensor, unless the Maf diags table is not scaled correctly...
Edit: Boost leak would result in the code aswell
I have installed a new maf as I thought this was the problem... But didn't get sorted...
I have checked for boost leak with a smoke machine n no leaks we're noticed..
I physicaly checked for vac leaks but there is no torn or broken pipes... So I'm guessing
There is no vac leaks...
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Gizmo,Gizmo20VT wrote:k03s MAF Cap should be just over 220g/s and k04 is 292g/s cappedGplay wrote:Sadly no
I thought maf limit for the 64mmID maf was 190ish, the 70mmID 220ish and the big s4 one was 292?
- Killerwatt
- Car Make: AUDI
- Car Model: S3
What i meant was, isnt the 64mm maf at 4.9xxx volts at around 190g/s. Hence the error in the software.
Guys could yourll please explain the 11 o clock plug position of the maf a little bit in detail,I'm still trying to make sense of it.does the element of the maf have to face exactly vertical or horizontal or at a certain angle? Does it really matter which angle it is in as its still calculating the amount of air goin in..its the first time I'm reading something like thie about the maf so I'm really to learn more.
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Angle does not matter....Glock wrote:Guys could yourll please explain the 11 o clock plug position of the maf a little bit in detail,I'm still trying to make sense of it.does the element of the maf have to face exactly vertical or horizontal or at a certain angle? Does it really matter which angle it is in as its still calculating the amount of air goin in..its the first time I'm reading something like thie about the maf so I'm really to learn more.
Lol sorry Gizmo... Have been really hectic... I forgot to update..
So far so good... I changed back to standard N75 as per you and everything seems all
Ok...
I had the N75j which was prob causing over boost at a certain RPM/Load.
I hope that error doesn't come back.. Crossing fingers
Ok...
- Stompie
- Boostleak Guru
- Car Make: BMW
- Car Model: 2006 120D
- Membership No: 1843
I heard and have experienced issues when the angle aint the same as per the airbox...?Killerwatt wrote:Angle does not matter....Glock wrote:Guys could yourll please explain the 11 o clock plug position of the maf a little bit in detail,I'm still trying to make sense of it.does the element of the maf have to face exactly vertical or horizontal or at a certain angle? Does it really matter which angle it is in as its still calculating the amount of air goin in..its the first time I'm reading something like thie about the maf so I'm really to learn more.
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Tried on mine with the donaldson and s2000 filters. Made no difference.
Hey Guys.
Hope alls well.
I have a AMK motor on a A3 with a 30/71 Turbo, I recently purchased a 3" maf rated 225bhp ( 06A906461M ), once I plugged it on the EPC light stayed on and the cars battles to rev up.
Any advice?
Hope alls well.
Any advice?
