Golf 7.5 clutch or gear problem need advice
I have mk7.5 1.0 tsi when changing gears from 1st to 2nd from 2000rpm to 3000rpm range I can feel something through the clutch pedal like a sort of vibration and the engine makes like as if the revs are hanging, happens when you change from 2nd to 3rd between same Rev range rest of gears are fine. Car is still under warranty but closest vw is far away does anyone know if it's gears or clutch or is it normal Rev hanging?
Re: Golf 7.5 clutch or gear problem need advice
I forgot to mention it has 15000km bought it on 12000km
- Le Clue
- Membership No: 1458
Could be a characteristic of the 3 cylinder engine?
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
Ive always had 1.4 tsi 4 cylinder so it's my first 1.0 3cylinder so it could be as you said character of the engine. Let me wait till next service and see what happens
- ICE King
Aaaah the famous VW rev hang,
Some say it's for unburnt fuel due to emissions, lag etc....., It's in the tune of the ECU, the exact reason only VW knows
Is it possible to tune it out from the ecu?
- Wolf Mk2 16V
My SO's Up does the same, I think it is most likely a bit of "flywheel effect"
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
