Jetta MK3 Oil pressure puzzle.
- Registered for: 1 year 10 months
- Car Model: 1995 Jetta III 1.8 CLX
Hi, new to the forum but have used a lot of the great advice & tips from here before. Thanks to all! Firstly, let me state that I am mechanically "challenged" but a keen "give it a bash" type person and this has probably got me into my dilemma. Secondly, please excuse my longish post:
One morning I started my '95 Jetta MK3 1.8 CLX and it sounded "noisy" at the top of the engine. I was advised that the oil pump was packing up and should be replaced ASAP.
I then bought and replaced the oil pump, sump gasket, oil filter and oil. Upon starting the oil light on the dash was flashing. From this forum I quickly realised that I had not primed the oil pump so I then redid the entire process using the same spares but this time primed the pump by splitting it and packing it with grease (A tip from mechanic).
On starting the oil light and noise were gone, I then used an external pressure gauge to test the oil pressure which was 3.5 bar (on the filter) at idle and rising to over 6 bar when revved slightly. I then took her for a drive and 2 km later the oil light came on along with a buzzer. On the off-chance it was a dodgy pressure sensor I replaced both, still no oil pressure but no buzzer now and the noise was back.
I retested the oil pressure using the external gauge at the oil filter and head oil sensors and it was back to zero. Any suggestions as to what I have done wrong or what I could have missed? Any advice would be greatly appreciated. My thanks in advance.
'95 VW Jetta III 1.8 CLX
- marzbars
- Car Model: 1988 Corrado 16V
- Membership No: 1316
Re: Jetta MK3 Oil pressure puzzle.
Look at the oil sensor on the oil filter
Current : 2011 Audi A5 2.0TFSI
Current : 1988 VW Corrado
Ex : 1984 VW Jetta GLS 1.6 Automatic
Ex : 1990 VW Golf CSL 1.6
Ex : 2005 Audi A4 Avant(B7) 3.0TDI V6 Quattro
Ex : 2003 VW Golf GTI Executive
Ex : 1995 VW Caddy 2.0 8v
Ex : 1996 VW Golf 3 GTS 1.8i
Ex : 1995 VW Golf 3 GTI
Ex : 1993 VW Chico 1.3
Hi Marzbars, thanks for the reply. I have replaced both sensors, head and filter, and the situation still remains the same sadly.
- Membership No: 2033
Is this the correct way of "priming" the pump? Surely grease will block it? Should you not use oil to prime it?MaverickMe wrote: ↑Sat Jun 11, 2022 10:28 am Hi, new to the forum but have used a lot of the great advice & tips from here before. Thanks to all! Firstly, let me state that I am mechanically "challenged" but a keen "give it a bash" type person and this has probably got me into my dilemma. Secondly, please excuse my longish post:
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Hi Howie-WP, according to the VW mechanic one can use either method however grease is quicker/easier/"cleaner" according to him. I have since removed the new oil pump for the 2nd time and there is only a small residue of any grease left, all the chambers are clear and clean yet still zero oil pressure.
Maybe the missing "grease" is now blocking the oil passage ways? Grease is less liquid than oil...... I'd check for residue close to the passage ways near the sensors and see......MaverickMe wrote: ↑Mon Jun 13, 2022 3:40 pm Hi Howie-WP, according to the VW mechanic one can use either method however grease is quicker/easier/"cleaner" according to him. I have since removed the new oil pump for the 2nd time and there is only a small residue of any grease left, all the chambers are clear and clean yet still zero oil pressure.
HOWIE-WP,
- EX-DOHCTOR
- Membership No: 712
Ordinarily clean fresh motor oil should be used to prime the pump. Not sure why you would want to introduce grease to the oil system.
Unless the idea is that the grease melts into solution in the oil when the engine heats up?
Agreed, sounds like BS. You are basically contaminating fresh oil. Oil <> grease .... If I was OP, I'd flush engine and try again, without the grease move....EX-DOHCTOR wrote: ↑Mon Jun 13, 2022 4:38 pm Ordinarily clean fresh motor oil should be used to prime the pump. Not sure why you would want to introduce grease to the oil system.
HOWIE-WP,
Hi DOHCTOR, I also questioned this method and as you say the grease melts into the oil and the minute quantity has zero effect on the oil.EX-DOHCTOR wrote: ↑Mon Jun 13, 2022 4:38 pm ....Unless the idea is that the grease melts into solution in the oil when the engine heats up?
- EX-DOHCTOR
Just as a matter of interest, what grease did you use?
Until this "melting" happens, it can block passage ways. Sounds like a BS idea; you are also mixing oils used for different jobs. But I don't really know and would not do this.....MaverickMe wrote: ↑Tue Jun 14, 2022 6:57 am Hi DOCHTOR, I also questioned this method and as you say the grease melts into the oil and the minute quantity has zero effect on the oil.
HOWIE-WP,
- Jetta2
- Car Make: VW, VW, Aprilia
- Membership No: 1087
It could well be some of the grease used has blocked the oil pump pressure reliefe valve in the open position, thereby dumping most of the oil pressure back into the sump instead of through the motor like it's supposed to do.
Seen it happen on two VW motors where the grease method was used.
Just prime the pump with normal engine oil, not grease. I have never had any issues with new oil pumps when priming with oil, I will never in a million years use grease to prime a new oil pump.
- leeban
- Registered for: 20 years 2 months
- Car Make: BMW
- Car Model: E90 LCi 320D
@MaverickMe Please update as you go along, interested to see what the issue was/is
2010 Audi A4 2.0T Quattro S-Tronic
Previous -
2010 Jetta 5 2.0 TSI DSG ... RIP (29/03/2013)
2007 Jetta 5 2.0T DSG (Sold 25/08/2012)
1989 Golf MkII GTi 16v Exec http://www.vwclub.co.za/phpbb3/viewtopi ... 11&t=75605 (Sold 29/04/2010)
2001 Jetta 4 2.0 Highline (Sold 21/11/2009)
Previous -
