Oil Mixing with Water
Mzobanzi
Registered for: 2 years 8 months
Post by Mzobanzi »
I changed gasket and took cylinder head for engineering but keeps pour water to oil section.
What can it be?
Sent from my M2006C3MG using Tapatalk
JCTPUBLISHERS
Registered for: 3 years 9 months
Re: Oil Mixing with Water
Post by JCTPUBLISHERS »
Check
if correct gasket was fitted
Cylinder head bolts tighten to correct spec
Could be block is crack
You will have to perform a cylinder head leakage test
Phat1983
Registered for: 16 years 5 months
Car Model: BM Trouble u
Post by Phat1983 »
Mzobanzi wrote: Thu Nov 25, 2021 2:58 pm I changed gasket and took cylinder head for engineering but keeps pour water to oil section.
What can it be?
Does the car have an oil cooler?
Bm Trouble U, German just like VW
JCTPUBLISHERS
What car is it?
Mzobanzi
Post by Mzobanzi »
JCTPUBLISHERS wrote:What car is it?
Caddy max 1.9 TDI.
Mzobanzi
Post by Mzobanzi »
JCTPUBLISHERS wrote:Check
Thank you for your input.
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
Also check the heat exchanger on the oil filter housing.
These are known for rusting through and causing oil and water to mix.
Sent from my M2101K6G using Tapatalk
