Gargling sound from engine
Scrib1
Registered for: 4 years 4 months
Post by Scrib1 »
Hey there members.
I have a 1999 VW Golf Chico 1600 Carburetor that recently blew head gasket. I had the head skimmed, replaced head bolts, put on a Payen gasket set, replaced the oil sensor’s, replaced flanges and did the right torque setting. The car idles ok, seems 2 have a slight misfire but made sure the motor was at top dead centre and made sure the firing sequence was correct.
I have a funny gargling sound when accelerating in any gear and I almost through in 4lt oil, and the dip stick shows the level is right. I need assistance. We tried advancing the timing but all that changes in the idling speed but that gargling sound still there. It’s actually very annoying…. Can some1 please advice?
JCTPUBLISHERS
Registered for: 3 years 9 months
Re: Gargling sound from engine
Post by JCTPUBLISHERS »
Where r u?
Does the sound get louder when you accelerate.
Did you check for the obvious like loose items or parts rubbing each other/
JCTPUBLISHERS
Where r u?
EX-DOHCTOR
Membership No: 712
Post by EX-DOHCTOR »
My ex used to make a gargling sound... but mostly only on friday and saturday nights :wink:
Scrib1
Post by Scrib1 »
The sound is only made when accelerating… other than that, when idling there isn’t any sound
Scrib1
Post by Scrib1 »
I checked 4 any loose parts. Nothing…
JCTPUBLISHERS
Hi perhaps mention where you are so that other Forum members can advise you.
You will need to take to a mechanic to check, not sure if noise is internal or not but does not sound right.
Scrib1
Post by Scrib1 »
JCTPUBLISHERS wrote:Hi perhaps mention where you are so that other Forum members can advise you.
I am situated in Wellington in the Western Cape. It sounds internal. Will be re-torquing the head soon so I think I will check the hydraulic lifters…
Car Make: VW, VW, Aprilia
Post by Jetta2 »
If the head bolts were torqued correctly the first time, there is no need to re-torque them. They are stretch bolts and one time use only. If you loosen the head bolts, take them all out and fit a new set.
