Mk1 carb to mpi conversion trasnponder
Hi
The conversation from 2003 citi golf carb 1.4 to 1.4i is done but now my computer box is closed and I can't find the plug for the transponder. How do I go about getting it to work?
Is there a plug hidden in the loom perhaps?
I have the chip in the key already so it's just picking up the signal from the chip I'm struggling with. The car will swing and sound as if it wants to idle but just dies again.
- EX-DOHCTOR
- Membership No: 712
Re: Mk1 carb to mpi conversion trasnponder
Do you have the pickup on the ignition barrel?
- EX-DOHCTOR
Great, that then runs to a black/brown control box, and then I believe that is wired to the TCI unit somewhere.
I'll have a look in abit and get back to you thanks
- EX-DOHCTOR
I think it might also be wired into the ignition coil.
Are the transponder keys and computer box from the same donor car?
I.E. the keys are already coded to the ECU?
Yes it all comes from the same car. I noticed my pickup goes into to loom so I have cut it open and trace it
Quick question should the transponder be wired to the ecu? The loom for the ecu is separate from the cars original loom so the tci or control box won't have access to the ecu.
Hi I don't know how to upload images but I traced the pickup wires and it goes to the clusters plug
- J0NN0
- Moderator
- Registered for: 12 years 3 months
- Car Make: No Name
- Car Model: Tekkies
- Membership No: 1725
How to Post a Picture
Jonno
2002 Volkswagen Lupo 1.4TDI - SAC: 87.7 kw 276.1nm
2018 Mitsubishi Triton 2.4 D/C 4x4
2006 Mitsubishi Colt Clubcab 2800 TDI
2003 Volkswagen Lupo 1.4 16v Auto
2007 SEAT LEON FR
1983 Volkswagen Caddy - Panic: 319.7hp 360nm
2008 SEAT LEON CUPRA - Oettinger: 191kw 352nm
2008 SEAT IBIZA CUPRA - HM Auto: 146.9hp 244nm
2007 SEAT LEON FR - KAR: 163.2kw 337nm
2007 Volkswagen Polo 1.6
2001 Ford Fiesta Flite 1.4i
VWCSA Membership Number: 1725
2007 SEAT LEON FR
- EX-DOHCTOR
So I stand to be corrected, but I am sure the transponder pickup sends a signal to the ECU, and if that matches, the ECU sends a signal to the TCI/Ignition coil to allow spark etc to work.
Now if you want the transponder keys to work correctly this will need to get sorted. It might ultimately be easier to unlock the ECU so that the transponder portion isn't a concern and then maybe fit an aftermarket Alarm and immobiliser.
car wont start had this issue back in 2016 Ecu keys and cluster must be from the same donor car unless its a open ECU
