1.8 16V KR
- ChrisMaxx
1.8 16V KR
Hi guys I have a 1.8 16v kr motor and rxi 45mm throttles and tdi crank that I want to swap in a mk1 N/A just wanna hear what mods can I do to get the motor little bit strong for weekend car not for drag just wanna hear what pistons , rods, cams, injectors etc can use to run just for nice power at altitude
Re: 1.8 16V KR
First check if the TDI crank will spin inside the block.
A 2.0l crank needs the block to be clearanced in order to miss enough things to work. TDI crank is longer by 3mm.
Iirc you will need a long block for a TDI crank and a KR is a short block.
