Have to replace Polo spark plugs every 5 - 6momths?
- Registered for: 20 years 2 months
Hi guys,
What could be the reason I have to replace our Polo's spark plugs every 5 - 6 months?
Thank you for any advice.
- Neuk
- Treasurer
- Membership No: 806
Re: Have to replace Polo spark plugs every 5 - 6momths?
Why are you replacing spark plugs every 5 - 6 months?
Car keeps misfiring and seems to some oil on number 2.
How much oil is the car using?
- Neuk
- Treasurer
Have you tried replacing just the number two cylinder spark plug? This would be to isolate the issue to that cylinder, or not.
Not yet will do so later this week, thank you for your reply Neuk.
- Neuk
- Treasurer
No problem, the oil is a bit of a concern though and may be fouling up the plug, so you can even look at simply cleaning it up and retrying it. My old Caddy used to foul plugs up from over fueling but cleaning them up sorted any issue out.
May be cylinder 2 rings are on the way out - engine wear.
Check https://www.championautoparts.com/Techn ... blems.html
If it was my car, I would do a compression test first and take it from there.
If one or more cylinders show 10%+ less compression than the others, it is time for an engine rebuild.
So I removed the spark plugs and no2 looks burned out with lots of oil? He do I post pics again?
Here are the pics
OkayJetta2 wrote:If it was my car, I would do a compression test first and take it from there.
Thank youJCTPUBLISHERS wrote:May be cylinder 2 rings are on the way out - engine wear.
Will do this today.Neuk wrote:No problem, the oil is a bit of a concern though and may be fouling up the plug, so you can even look at simply cleaning it up and retrying it. My old Caddy used to foul plugs up from over fueling but cleaning them up sorted any issue out.
Thank you Neuk, after cleaning all the plugs up and the oil it seems that oil is pushing out from the oil cap. Cleaned it all up and replacing the cap. Took her for a spin and everything is okay. Thank you everyone for you input much appreciated.MarlonC wrote:Will do this today.Neuk wrote:No problem, the oil is a bit of a concern though and may be fouling up the plug, so you can even look at simply cleaning it up and retrying it. My old Caddy used to foul plugs up from over fueling but cleaning them up sorted any issue out.
- Neuk
- Treasurer
Pleasure I am glad that you made some progress but keep an eye out on the oil.MarlonC wrote: ↑Thu Jul 22, 2021 12:29 pmThank you Neuk, after cleaning all the plugs up and the oil it seems that oil is pushing out from the oil cap. Cleaned it all up and replacing the cap. Took her for a spin and everything is okay. Thank you everyone for you input much appreciated.MarlonC wrote:Will do this today.Neuk wrote:No problem, the oil is a bit of a concern though and may be fouling up the plug, so you can even look at simply cleaning it up and retrying it. My old Caddy used to foul plugs up from over fueling but cleaning them up sorted any issue out.
One last thing, that no.2 plug has lots of rust on it, be careful how you wash your engine. Try to avoid spraying anywhere near the coils. Polos like to trap moisture in the spark plug wells, causes misfires and also damages the coils.
