Mechanic Recommendation-Ford Figo
- Car Model: 2006 polo 9n3 gti
Good day gents,
As the topic states I'm looking for a recommendation for a mechanic in the East Rand to solve an issue on a ford Figo 1.4N/A duratec.
The issue arises when starting when the vehicle is cold, a general engine fault warning pops up on the dash and rpm is limited to around 1500rpm. If you leave the vehicle to idle for a few minutes and switch off and on it goes away and the car drives normally.
I have taken the car for a diagnostic scan and after identifying the error as air pressure sensor related, I changed the sensor but the issue remains.
I'm looking for a mechanic that can diagnose and solve the issue and preferably do it within a few days time as the vehicle is used to travel to work and back.
I appreciate your recommendations.
- EX-DOHCTOR
- Membership No: 712
Re: Mechanic Recommendation-Ford Figo
Have you tried the Ford Dealer?
- aristo92
- Membership No: 3133
Hi Lodi, speak to Yosh from Dark Artz. He is based in the east and should be able to assist.
Sent from my SM-N986B using Tapatalk
Thanks, I did speak to Yosh and unfortunately he won't be able to assist
- aristo92
Lemme see who else is this side of the world. Will see what I can find out.Lodewyk wrote:Thanks, I did speak to Yosh and unfortunately he won't be able to assist
- V6 Capri
- Registered for: 12 years
- Car Make: Ford
- Car Model: V6 Capri
Speak to Douglas at D-Tec Motors in Pomona - 072 642-1693
He always sorted my ST170.
2016 VW Touran 1.6TDi
1971 Baywindow project
1964 Ford Anglia 997cc
1972 Ford Capri 3L GT
1994 Escort Cosworth (replica)
1996 Escort 2L Zetec
- Car Model: Cti
- Membership No: 2095
Hey Bud,
My wife had a Figo some years ago and also had a very similar issue on hers. It was under warranty and they had replaced the TB for the issue to go away.
I cannot remember clearly the finer details but I do know it wouldn't rev up once a while when started therefore the TB was replaced. Hopefully that gives you some direction with regards to the issue you having.
Thanks for the replies, I have booked the car in at Dtec today and hopefully they can resolve the issue. I will have a look at the throttle body as a possible culprit thank you
- V6 Capri
- Car Make: Ford
Problem sorted?
Just some feedback, Dtech replaced the map sensor was hell expensive but the problem still persists. Starting the car and manually revving it a bit seems to solve the issue though
- V6 Capri
- Car Make: Ford
That sucks. Did you take it back to him?
Yes took the car back. Issue was not resolved, sold it as is.
