Hi Guys,
Please help, is there a trick to get a 87 citi sport fuel tank out. I have dropped the entire sub-frame and detached the tanks straps and it aint moving an inch, am I missing something?
Citi Sport fuel tank removal
- dazza
- Car Make: VW and VW
- Membership No: 1327
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
Re: Citi Sport fuel tank removal
Filler neck removed?
- EX-DOHCTOR
- Membership No: 712
Did you disconnect the filler neck and the connections under the rear seat?
- dazza
Filler neck loose. I did not see any connections under seat, I need to take a closer look then
Darryn Van Rooyen
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- EX-DOHCTOR
So under the rear seat there will be a round metal plate with 3 screws, lift that off and you should then see the fuel tank float, there should be 2 fuel lines and an electrical plug like so:
This shouldn't be holding the tank up but would need to be loosened to get the tank out. Once you've sorted there maybe give it some light percussive maintenance with a mallet.
- EX-DOHCTOR
One line should be a supply line and the other a return IIRC.
- EX-DOHCTOR
All sorted?
- dazza
Its out just needed some encouragement. Seems I found my issue, the feed lines from the tank are the original lines from 1987 now completely perished so hence why no fuel was being moved between tank and carb/fuel pump. Clearly big vacuum leak going on.
Will be changing all rubber fuel lines from tank and around the back area of the car as a result. Hope to have the car driving again in no time.
Darryn Van Rooyen
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- EX-DOHCTOR
Any updates bud?
