Cooling system
- Registered for: 3 years 1 month
- Car Model: MK1 1.8
Cooling system
Hi all im having a problem with my radiator switch so i connected it to the ign coil, so now it runs when ever i turn ign. Is there a way that i can connect it to a switch? so that i can turn it on manually when i need it? or is there another way?
- EX-DOHCTOR
- Membership No: 712
Re: Cooling system
Why not just replace the sender switch on the side of the radiator?
Re: Cooling system
Yes replace the switch if it is faulty or get an auto electrician to sort the problemEX-DOHCTOR wrote:Why not just replace the sender switch on the side of the radiator?
Re: Cooling system
thanks for the replies
- EX-DOHCTOR
Re: Cooling system
Have you been able to sort the issue out?
- Neuk
- Treasurer
- Membership No: 806
Re: Cooling system
Yes, don't mess around with what is otherwise a perfectly fine cooling system.EX-DOHCTOR wrote: ↑Tue Mar 30, 2021 3:38 pm Why not just replace the sender switch on the side of the radiator?
Re: Cooling system
