Hi everyone
I recently noticed a staggering drop of power in my 2010 Jetta 5 1.6, it lined up with a service and cambelt change, so I asked the mechanic to give it a drive and look around because it has no power output at all. I can be doing120 km/h on the highway and come across a decent hill to go over and the speed drops to about 80 km/h, this was not the case before.
Since I had an intermittent EPC issue (Fuel injectors and Throttle body have been replaced), he drove it around and is pretty convinced my catalytic converter is blocked/getting blocked which is causing the lack of power as well as the occasional EPC light. He also drove it without the catalytic converter attached and said there was a world of difference in the power.
My question is should I go ahead with a CAT delete or is there a way to "clean" a CAT, I have heard of the Italian tune-up method which I don't mind giving a go. Also If I go for a CAT delete what do I need to make sure the EPC light or any other check engine lights don't crop up, do I need to use one of the CAT foolers/spacers like the ones below?
https://www.bidorbuy.co.za/item/4875563 ... erter.html
OR
https://www.bidorbuy.co.za/item/5027563 ... g_Nut.html
If I do go with a CAT delete I want no issues of EPC or check engine lights afterwards.
Has anyone done this ? and what issues did you encounter?
I have had the car now for 3 years and intend on keeping it for a good while more, but these issues with the EPC light and now the loss of power is putting doubt in my mind.
Any help and info is highly appreciated
Jetta 5 1.6 BSF Catalytic converter blocked/delete
Jump to
- General
- ↳ General Announcements
- ↳ Club and Forum Queries
- ↳ Introduce Yourself
- Events
- ↳ VWCSA Events
- ↳ VWCSA Pictures and Videos
- ↳ VWCSA KZN Events
- ↳ Non-VWCSA Events
- ↳ Non-VWCSA Pictures and Videos
- Technical Discussions
- ↳ Technical: Motorvehicle Related Discussions
- ↳ TDI Engines
- ↳ N/A Engines
- ↳ Forced Induction Petrol Engines
- ↳ General Tech Discussions
- ↳ Technical: I.C.E. Related Discussions
- ↳ Technical: Detailing Related Discussions
- ↳ Technical: Volkswagen Vehicle Test Information
- ↳ Technical: Frequently Asked Questions
- ↳ Panic's Place
- ↳ TSC Garage
- ↳ Digit - Vehicle Tracking Fleet Management Fuel Monitoring
- ↳ Chameleon Wrap & Shine
- ↳ Auto Agent
- ↳ Crazy Detailer
- ↳ GearTronix
- ↳ Goldwagen Kensington
- ↳ Good Enough Garage
- ↳ Liatros Recycling
- ↳ KNS Customs
- ↳ Motorlease
- ↳ MMS Auto
- ↳ WheelIndex
- ↳ VAG Technik
- ↳ VAG Cafe
- ↳ RevLimit ECU tuning SA
- ↳ Racer's Edge
- ↳ Pristine Detailing
- ↳ Poor Boys
- ↳ NF Additives
- ↳ RetroFitters
- ↳ Wheels & More
- ↳ Forum Section Advertisers
- ↳ Delarey Racing Developments
- ↳ Goldwagen Delarey
- ↳ Huber Motorsport
- ↳ NF Additives
- ↳ THANAS Performance
- ↳ VW The Glen
