is there a way to connect to the ECu of a Vr6 jetta
i want to help my friend with his car, it losses power while driving, might be coil pack
Try to connect to ecu via vag com but no luck, the doesn't use immobilizer like normal mk3
i google the pin out for the vr6 and its pin 21 Data Link Connector (L-Line)
can I hooked this up as the mp9 with only earth power and direct line to pin 21
Thnx in advance
vr6 ecu
- Car Make: VW & Honda
- Car Model: VR6 & Type R & RS3 & R32
Re: vr6 ecu
You need to code the key (transponder ring) to the ecu.
Current rides:
2021 Audi RS3 Sportback
2009 Honda Type R Championship Edition - Standard for now
2008 VW Golf R32
1996 VW Golf VR6-T 2-Door Highline 315Whp - Panic Mechanic tuned
Ex-Rides :
2012 Audi RS3
2000 Honda Civic Vtec - NA 168Whp - Panic Mechanic tuned
1996 VW Golf VR6-T 300Whp - Panic Mechanic built and tuned
1992 VW Golf 2 2.0 GTI 16v Executive
1989 VW Golf 2 1.8 GTI 16v Executive
1992 Toyota Conquest RSI
1981 Ford Granada 3.0
1980 Opel Kadette 1.3
2008 VW Golf R32
Ex-Rides :
2012 Audi RS3
Re: vr6 ecu
oops i totally read that incorrectly... never mind what i typed LOL
Current rides:
2008 VW Golf R32
Ex-Rides :
2012 Audi RS3
2008 VW Golf R32
Ex-Rides :
2012 Audi RS3
Re: vr6 ecu
Hi Guys
anyone that can assist on Vr6 fuel pump. got the fault code 01259 Fuel pump Relay (open or short to ground)
Ross tech explain it as faulty fuel relay or wiring connection to ground
The pump keeps on running while the ignition on
thanks in advance
thanks in advance
Re: vr6 ecu
Change the relay for a new one.
My VR did the same a few years ago. Got a new relay from Goldwagen, problem solved.
Re: vr6 ecu
Thanx a lot will check tonight
