Hi guys,
I just need some help regarding setting up launch control on my Dicktator, settings are as follows in the pictures, I assume it is setup correctly, however I am unsure as how to wire it up regarding switches and which wires go where, any help will be appreciated.
I’ve tried using the POT wire to one pole on the switch, and then the 5v wire to the other pole on the switch, but does not work. The switch only has 2 poles.
Dicktator Version: 16
STD Dicktator
Dicktator Launch Control setup and wiring
- Jrmunger199
- Car Make: Nike
Re: Dicktator Launch Control setup and wiring
Standard Dicktator does not have launch control, needs to be added when ECU is taken to them.
If I remember correctly the wiring, just checked on the website, its just a normally open switch wired between RED/White wire and Green/Yellow on the Dicktator.
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 01 Golf 4 Tdi
- Jrmunger199
Okay sweet thank you, I’ve heard stories that the new Dicktator STD boxes had it built in, but maybe not, I had it wired in right then maybe doesn’t have it, will send it through to Dicktator and see what they sayRudi46 wrote:Standard Dicktator does not have launch control, needs to be added when ECU is taken to them.
- Registered for: 3 years 1 month
Hey Gents.
I've got a worked 2l 8v throttles, running it with dicktator Std.
I just want to know how to install 2 step on it? or what extra I must get to make it work? or where I can activate it. my location is cape town. Would appreciate it
- Jrmunger199
Dicktator std had to be sent it to Chris Dicks to have launch added to the ecu, there’s just 2 wires that it runs to on the ecu, I’ll find the pin outs and let you know, but I had the same thing with std, ecu has to be sent in and IIRC it costs R850MickeyG wrote:Hey Gents.
