I ran a scan through the central locking units on each door via vcds. Non of the doors have had an issue stored.
I do have the problem where the rear left central locking works intermittently and the rear right is stuck in safe mode. Does anyone know how to get the lock out of safe mode so that i can remove it from the door?
I have read that the locks has a micro switch that is the issue. i would like to remove them and replace/clean them up. Any clue where i can get these switches from in Durban?
Central locking stuck on safe
- Car Make: SEAT
Re: Central locking stuck on safe
If you can't get the door to open the conventional way you'll have to first try to get the door card off - and then start drilling.
AFTER you have already got a replacement lock, of course.
Good luck!
Good luck!
- Wheel Whore
Seen the drilling video on YouTube. Will give it a try this weekend.
- Car Make: SEAT
Tip: Get another lock and draw a template do that you can drill in the right place, first time.
