Sparking issues
- Kyle28rsa
- Car Make: volkwswagen
- Car Model: MK1 1983 GLS
Sparking issues
I recently redid my motor and nearly everything has been replaced. I did a test on ignition by removing one bogey cord at a time to test if there is spark. Engine bogs down when removing 3 of the 4 cords. When i remove cylinder 2's cord there is no change in idle.
Things ive done are as follows:
Replaced spark plugs
Replaced all bogey cords
Replaced dizzy cap and rotor
Is there anything else i can do to resolve this
Engine specs are
2l 8v ady
276 cam
Ported and gas flowed
Note that tuning was not done to air fuel mixture yet
Engine specs are
2l 8v ady
276 cam
- chucker02
- Car Model: Citi ADY
Re: Sparking issues
Does it spark on cyl 1 and 2? I assume the car is misfiring? Have you checked the injectors on 1 and 2?
1971 VW beetle
1971 VW beetle
- Kyle28rsa
Re: Sparking issues
Cylinder 1 is fine. Thats one thing i did not check is injectors. Will have it looked at. Should have spare ones laying around
- chucker02
Re: Sparking issues
Worth a shot
1971 VW beetle
1971 VW beetle
Re: Sparking issues
If you don’t have spare injectors, swap 2 around and check if fault has moved.
Did you test the compression and compared cylinders pressure readings?
- Kyle28rsa
Re: Sparking issues
Thanks guys. Injector 2 was dead. Swopped it out and now its perfect. Tested cylinder pressure just in case. All is perfect. Thanks again
- chucker02
Re: Sparking issues
Good job, glad it sorted
1971 VW beetle
1971 VW beetle
- Kyle28rsa
Re: Sparking issues
Thank you. Now that the car is running. There is heavy pressure coming out of the exhaust. Is it good or a bad thing? And also if i leave the cars tuning on standard while i have a 276 cam in would it cause any issues?
Re: Sparking issues
If you are using the std 45-51mm exhaust system, that will cause some pressure. For a 2L it is advisable to use 57mm exhaust system as a minimum.
The pulsation from the 276 duration cam will also contribute to more pressure felt at the rear. Not to worry.
- Kyle28rsa
Re: Sparking issues
Yea the exhaust still standard. Thanks for the clarification. Hopefully keeping the ecu standard wont cause any issuesPapaJo wrote:If you are using the std 45-51mm exhaust system, that will cause some pressure. For a 2L it is advisable to use 57mm exhaust system as a minimum.
Re: Sparking issues
It will need a tune to get it properly sorted.
