I have a 2l 8v ady cylinder head that had some work done. Work that was done is as follows:
Port and gasflow
Double valve springs
276h cam fitted
If i fit this head back onto the block with the stock 2l mp9 ecu still intact, would the ecu adjust accordingly for the changes/ would i have to adjust air to fuel ratio/ would i have to get an aftermarket ecu?
Headwork and ecu tune
- Kyle28rsa
- Car Make: volkwswagen
- Car Model: MK1 1983 GLS
- Car Make: Ford
- Car Model: Focus ST
Re: Headwork and ecu tune
You would need management to get the most out of your mods
2010 ST225 - 238kw 439nm
- Kyle28rsa
Thanks for the info. Would it be able to run normally (without taking advantage of the work done) without managementGreenz wrote:You would need management to get the most out of your mods
- chucker02
- Car Model: Citi ADY
Yes but the mp9 might struggle a bit with idling with the 276
1971 VW beetle
1971 VW beetle
- Kyle28rsa
Meaning it would die out sometimeschucker02 wrote:Yes but the mp9 might struggle a bit with idling with the 276
- chucker02
Yes but only on cold idle. Does the throttle body have a manual idle screw installed? When I fitted a 282 on my ADY with spitronics management it did not want to idle at all when cold. It only idled once up to temp
1971 VW beetle
1971 VW beetle
