Howsit guy's, i have a 2006 velociti 1.6i, she swings but refuses to start, I tested the plug that fits to the fuel pump and there isn't any power going through, i have checked the normal fuse box on the driver's side and all seems to be fine,
Any idea what could be the problem?
Velociti not starting
- Registered for: 4 years 7 months
Re: Velociti not starting
HI Guys
i have a different problem - my car starts perfectly everyday but when she stands for more than two days the car sounds like it has a flat battery. you kick start the car and it has no problems turning over. i have replaced the battery in the car as well as the positive and negative cables on the battery. Any ideas why this happens and how i can prevent it from happening again ?
i have a golf MK1 2007 velociti
thanks
thanks
- chucker02
- Car Model: Citi ADY
Hey, please check the fuel pump relay. Its under the steering wheel. There are 2 relays down there. One for the wipers and one for the fuel pump. They always get water somehow and stops workingNoelin26 wrote: ↑Thu Sep 12, 2019 7:00 am Howsit guy's, i have a 2006 velociti 1.6i, she swings but refuses to start, I tested the plug that fits to the fuel pump and there isn't any power going through, i have checked the normal fuse box on the driver's side and all seems to be fine,
1971 VW beetle
1971 VW beetle
- chucker02
Hey, something is busy draining your battery, either a tracker unit or something that is not turning offStorm Huxham wrote: ↑Thu Sep 12, 2019 7:32 am HI Guys
thanks
1971 VW beetle
1971 VW beetle
Hi Chucker02
thanks for the feedback - i have removed the aftermarket central locking and alarm system. - i dont have a tracker in the car at the moment.
the cab light is not on and removed the globe, the radio face is off. so im really lost here.
could it maybe be the fuel pump not switching off properly, i cant think of anything else that could cause this problem.
do you know a good auto electrician around the alberton area ?
Hi guys, on my 2006 velociti,
My indicators and hazards are not working yet the light on the dash comes on, i have checked the fuses and they are fine, but there is no power going to the indicators, none of them work
None of the indicator lights are coming on, there isn't any power going to them yet on the fuse box it's all well
There are two big fuses next to the battery.Noelin26 wrote:Hi guys, on my 2006 velociti,
Buy new ones
