Good Day People,
I'm new to the mk1 golf family.
I recently bought me a 2l 8v with a dictator management. (my first car)
I serviced my car Saturday past, and now it doesn't want to drive.
all i did was change the spark plugs, petrol filter, and oil. (oil filter was a struggle to take off so i left it on because my old spark plug was not in a bad condition)
I had a friend of mine look at the car, but couldn't determine why the car is unable to drive.
The car starts up and idle but then dies after a few minutes.
I'm thinking it could be one of two things or both. My 3 pin coil or my dictator management.
can anyone please assist?
I wouldn't want to take it to be tuned and than that's not the problem.
Regards
MJ 2l 8v.
2l 8v not driving after i serviced it.
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Re: 2l 8v not driving after i serviced it.
Double Mmmhhh
You need to make a plan bro, remove and change out that Oil filter.
You cannot put in new oil into a motor with old oil filter.
Sent from my SM-A500F using Tapatalk
- Car Model: Polo vivo
Get yourself the oil filter wrench type, not the belt, get the 3 jaws one, it will take it off
Vw Polo Vivo 1.4
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
what fuel filter are you using?? As in brand?
Problem sorted.
wires from my coil to my distributor was laying against my fan, so each time I my drove my car the fan was eating away wires.
- Unobeat
Glad you sorted.
