Hi Guys,
I have a 2004 polo 9n 1.6 BAH. wanna drop a 2.0 bbx or apk in. not sure what needs to be changed??? or added? after market ecu? will the lugs all work with current ecu? guessing mounts are the same? gearbox? I want to do it myself btw
Thanks in advance guys.
Polo 9n 1.6 to 2.0...
Re: Polo 9n 1.6 to 2.0...
It is probably doable. Let us know how it turned out. If you can adapt the map you would most likely be able to make the stock management work.
