Hi Guys
Need some advise/help please
As per the header, I need to replace the fuel pump on my 2009 Citi Rox 1.4i as I believe it is in its failing stages. (constant louder than usual whining sound and starting the car requires a longer ignition swing and a pump of the accelerator pedal)
My question is, will changing out the unit underneath the car cause any disruptions in the dictator management settings that will require some sort of remapping or will it be a simple out with the old and in with the new
As always, all help is infinitely appreciated
Ahmed
Replacing Fuel Pump while running a Dictator System - Citi Rox 1.4i
- Car Model: Citi Rox 1.4i
- Old School Quintin
- Car Model: MK1 16v
Re: Replacing Fuel Pump while running a Dictator System - Citi Rox 1.4i
Do you still have the standard fuel pressure regulator on the enige or do you have a stand alone one
2008 VW CitiRox
Abf 45mm ITB
Under construction
Seeking ponies
Abf 45mm ITB
Under construction
Seeking ponies
Should have no effect on the mapping if it was orginally done on a good pump and you are basically restoring to that.
Thanks Panic
Yes the installation of the management was pre- whining.
Will source the pump from the local Goldwagen
@Quintin - The motor is still stock beside the management system
Ahmed Syed
