power for my 2l 8v
Smiley G
Registered for: 4 years 11 months
power for my 2l 8v
Post by Smiley G »
2.0 Ady
298 estas Cam.
My head is ported and flowed.
Dictator std.
I still Have 50mm exhaust , 1.4i intake, injectors and 1.4i Branch.
I made 104kw. im not happy with this figures
What Can I do to make More Power. im 8n durban in the coast
Re: power for my 2l 8v
There are many experts in durban that knows how to do that. I'm sure somebody from your home town will pop in with a reference.
Your 50 mm exhaust is a restriction though
gPhilipC
Car Model: Golf MK5 tdi, Caddy Utility
Post by gPhilipC »
I am running more or less the same setup.
2l but all standard
Throttles
298 cam
Branch
Free flow
Spitronics
Making 103kw. But i believe its tuned conservatively... The engine stops reving at around 5800rpm, belive it can be higher? Maby?
Ex Rides
VW beetle 1600
Yamaha RZ 350 YPVS Full racing spec motor
VW Beetle 1.8 Motor
Jetta 2 1.8 (Stolen)
Jetta 2 1.8 (was in a sad state when i bought it)
1998 BMW 235 TDS (Respect for the diesel)
VW Citi 1.3
VW Jetta 3
2007 Kawasaki Verses 650
1996 Nissan 1400 AKA "scrappy"
Current Rides
2005 VW 1.9tdi - decat, and tune...
2001 VW Caddy Utlilty - 2l, standard block and head, throttles, branch, free-flow, 298 cam, spitronics management.
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
Smiley G wrote:2.0 Ady
298 estas Cam.
Dictator std.
Is this a wheel kW figure or is the dyno correcting for flywheel?
Also who did the tune and the power run?
I ask because there are no two dynos that are the same and even doing the run on a cold day vs a warm one can make a big difference.
Post pics of the dyno sheet, it will give more info.
@PanicMechanic will also agree, power figures are more of a guideline and less of an absolute number. There are a number of variables that will affect the final reading from one dyno vs another.
If one excludes the actual dynamometer and how it's set up from the equation, there are a few things that will change your numbers on a given day, such as ambient temperature, fuel temperature, engine temperature, humidity and altitude. All these things affect air density and air density effects power numbers.
I suggest you visit Banks Power on YouTube, they explain all of this very well in an easily understandable way.
I also suggest doing a number of runs over a period of time with different conditions, take the average of all of them.
Finally for an N/A 2.0 8V anything over 100kW is respectable, but if you want to squeeze more from the motor, you need to look at the whole picture as a giant air pump. Examine everything that has to do with moving gasses and work out how to reduce any restrictions and improve gas velocities both entering and leaving the motor.
Good luck and keep us updated with your progress.
Smiley G
Post by Smiley G »
gPhilipC wrote: Thu May 09, 2019 9:36 pm I am running more or less the same setup.
2l but all standard
Throttles
298 cam
Branch
Free flow
Spitronics
my engine rev's up to 6800rpm but i still cant go with the power i made , acutally my car is gona be out with a new exshaust system tomorrow let url know on the results
Smiley G
Post by Smiley G »
please can someone help me im changing my fuel pump 2 a 0.44 6and half bar and i want to know thats the best top feed injectors for my mp9 looking at max 450cc injectors
Quik-Trix
Membership No: 3004
Post by Quik-Trix »
57mm Freeflow and Decent branch should free it up a bit more.
No need to get a bigger pump or injectors.
What power do you think you would be happy with?
Smiley G
Post by Smiley G »
Quik-Trix wrote: Thu May 16, 2019 8:25 pm 57mm Freeflow and Decent branch should free it up a bit more.
around 150/155hp seeing guys doing it here in durban is amazing but the bad part is no1 is willing to share infomation with you so every man for them self
Quik-Trix
Membership No: 3004
Post by Quik-Trix »
Change the exhaust and then see.
Don't see you say anything about bigger valves done to your head, there's some power in there as well
davek
Registered for: 9 years 1 month
Car Model: Polo 1 Classic
Post by davek »
Hi Guys..
I have just installed a 2l 8v AGG into my 2002 Polo Classic. Still have the original computer box for the 1.6 AFX motor which i removed. I do have a Uni-Chip that was installed in 2007... The car idles rough as was expected and is a little hesitant when pushed a bit (Seems to be fuel starvation) What is my next step.? and is anyone willing to assist me...I am based in JHB (Live in Kempton park / Work in Linksfield).
Please email, Whatsapp or call me
Dave
daveekruger@gmail.com or 0793624141
:deadhorse:
8VALVE-zn
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Post by 8VALVE-zn »
Tune the car. If in JHB try with Panic Mechanic on the forum
I don't tune unichip. Try dastek in pretoria.
P1LAYA-ZN
Car Make: Audi, VW and Toyota
Car Model: S3 8L 20VT & Mk 1 Jetta GLi
Post by P1LAYA-ZN »
My 2L 8v ADY MK1 Jetta made 105kw and 202nm @ Autotrix in DBN about 7 years ago, and it was impressive then.
So 103kw is a good number for an 8V.
I have a friend with a Mk1 golf making around 130kw with his 8V, but he has ITB's so maybe consider this option.
Also, maybe lightening the flywheel will give a few more kws, although less torque.
#Builtnotbought
P1LAYA-ZN wrote: Tue May 21, 2019 10:00 am
Really?. not that old wife's tale again. So seeing that you perpetuate it please can you explain to me.
a) the physics of how an inanimate object that is being spun by an engine can create or destroy torque. Please show me which of newton's laws you are using here.
b) how is it possible for something that removes torque can create HP? Please use formulas of how Hp is calculated to display how that is possible assuming the engine is red lined at the same rpm.
Maybe if you use inertia we will be on the right track - not torque and KW.......
P1LAYA-ZN
Post by P1LAYA-ZN »
Hence I said Maybe, but Panic knows more and is probably correct.
I would hate going back to my Physics 101 books to attempt to explain, LOL
Lightening Flywheel will just make the car rev up faster and since he is chasing Power on a N/A 8V, I think some big funds need to be spent here...big valve head, raising compression, ITBs, maybe even a cross flow head.
Its hard and expensive just making a few more kws on a N/A 8v, maybe even consider the ABF option if you gonna be spending that much.
Keep us posted.
I am also thinking about ITB's, but more for the noise :-)
#Builtnotbought
Lighter flywheel makes it more responsive and will help it accelerate faster on the road. The only thing it robs is engine inertia so you have to use a bit more clutch or throttle to pull away. Not something anything but a learner driver will struggle with.
Yes there are lots of other areas of work - all airflow or capacity related. His main complaint is that nobody shares with them in Durban but there must be gazillion posts on this very forum of exactly how and I really don't feel like rehashing years and years of the same info.
In short - in engine is an airpump. put more air in so you can burn more fuel - voila - more power.
THANAS
Car Model: AW Polo GTi
Membership No: 2035
Post by THANAS »
Turbocharge it :evil:.
PapaJo
Registered for: 14 years
Car Make: VW's
Post by PapaJo »
THANAS wrote: Wed May 22, 2019 11:21 am Turbocharge it :evil:.
:thumbup:
davek
Post by davek »
Good Morning Guys.
Does any one have a 2.0l ECU they are willing to part with. I have a perfectly good 1.6 unit to swop..?
:deadhorse:
Why? Just let somebody load a 2l map on yours. Speak to trevor greene - he is in pretoria 082 309 5033.
Smiley G
Post by Smiley G »
thanks guys for ur help , i have just purchased itbs for my 2l 8v will be fitting it on soon , i am going to ligten the fly wheel to get improvement on my acceleration, because it cry's to rev as fast as i want it to , i did change exshaust aswell and i feel the car moving much better , thinking off getting a nice ls trick box for the car will update you guys , thanks panic for ur help
Tashveer
Car Model: Cti
Membership No: 2095
Post by Tashveer »
Smiley G wrote: Tue May 28, 2019 10:23 pm thanks guys for ur help , i have just purchased itbs for my 2l 8v will be fitting it on soon , i am going to ligten the fly wheel to get improvement on my acceleration, because it cry's to rev as fast as i want it to , i did change exshaust aswell and i feel the car moving much better , thinking off getting a nice ls trick box for the car will update you guys , thanks panic for ur help
Howzit dude, who is tuning the car for you and who did the headwork on your car?
1993 CTi ABF
2004 Citi Life 1.6i
8VALVE-zn
Car Make: VW Golf 1
Post by 8VALVE-zn »
Durban tuners that are good: 1) Vino @ Autotrix, 2) Kumaren @ Electroboost, Rino @ Fastcar
What fuel does the car run on? If pump fuel then be happy with that number.
8VALVE-zn
Car Make: VW Golf 1
Post by 8VALVE-zn »
If you want to go with a smaller cam (just one size smaller than yours) then you can drop me a PM.
davek
Post by davek »
OK...I am back Guys.. Followup on my 2.0l AGG conversion..
1. Trevor Green remapped my ecu
2. Dastek remapped the unichip..
3. Better
..but not good enough
4. Car pulls well enough to 4500 rpm and seems to starve of fuel..
5. Tech at Dastek says he thinks motor is not getting enouğh air or fuel..
6. I was told that the 1.6 injection manifold and pump would handle the fuel demand.??
7. I have stainless steel branches on for the 1st section and then standard exhaust to the end..
On another topic..
1. My original millenium ediition ecu was stolen so i got hold of an older model one.. The rev counter stopped working.. After Trevor Greene remapped it the Rev Counter works but when i plug in the speedometer sensor the car cuts out as soon as i put my foot on the accelerator. I replaced the sensor on the advice of a chap in Cenurion but that hasn't helped..
Any ideas on resolving these two issues would be greatly appreciated.
:deadhorse:
