Could you please assist and tell me where I will find my knock sensor?I drive a 2007 1.4 VW Polo Trendline (BLM Engine) TIA
Knock sensor location
Re: Knock sensor location
Under the inlet manifold on the the block in between the 2 and 3 cylinders.JpTheron1984 wrote:Hi guys
Take the manifold off to get to it. It's an utter pain otherwise.
Why on earth do you want to change it any way? Unless you've taken a hammer to it on the bench those things never break.
Post some details of your problem and why you believe your knock sensor is to blame and maybe we can help you.
I am experiencing ignition timing noise.When the car is under load I hear a pinging sound.Up a hill or with the aircon on.It has gotten progressively worse and doing it even when car is not under load.
first go with a vcds scan and look at timing values. See if you see any timing retard. If so then it's working fine.
Get it on a dyno and see what the fuelling looks like. if it is lean it could do the same
Could be that the fuel pump is giving up and not supplying enough fuel, it would have the same effect.panic-mechanic wrote:first go with a vcds scan and look at timing values. See if you see any timing retard. If so then it's working fine.
While it's on the dyno and AFR is being looked at, have a fuel pressure gauge connected at the same time.
One more thing, the fuel filter on your car has a built in fuel pressure regulator, if it has become faulty it could reduce the amount of fuel going to the motor.
Perhaps start there and see. Make sure you buy the right one, there are 4 types, yours should be a Z156 with a 3Bar pressure regulator.
Thanks for the replies guys.Tell me one more thing.I read somewhere that you can just unplug the knock sensor and drive it without to see if that is indeed the culprit?Is that true or will it cause damage?
sure you can unplug it. Will make a fault on the management. but it should run still
