Good Day All
Is there someone that can help me out with a map for a vw mk1 1.4i running on Dicktator STD ?
The motor is standard , I changed from MP9 to Dicktator as the MP9 was giving me some problems, after 2 months of the running and getting tuned, the Dicktator decided to burn out, I got the box sorted but I dont have a map.
If someone can assist will be highly appreciated.
Thank You
VW MK1 1.4i Dicktator Map Required
Re: VW MK1 1.4i Dicktator Map Required
ask the original tuner for it. He should have saved a copy.
- Registered for: 1 year 3 months
Hi
I have a citisport 1.4i 8v
I need a std diktator map with cold start, the installer only had a 1.6 map, changed because mpi box got damaged due to water leaking in
The car has a branch
200cc injectors
And has a screamer pipe instead of original air box
Any help will be much appreciated
200cc injectors
- Car Make: mk1
- Car Model: GTX
Contact these guys. They might be able to assist you
https://dicktatorspecialist.co.za/produ ... uct-page=3
