Hi please help with a possible solution to my 1.4 citi golf mk1 2007
When turning on the ignition to start the car, there was a plactic burning smell inside the car.Indicators,wipers, brights, hazzrads and break lights are now not working. Checked the fuses and replaced fuse 19 (as seen in related posts) also replaced relay which smelt burnt.
Wipers moved slightly and is now stuck.. There is still no indicators.
Hazards work when ignition off however when turned on does not work.
Please help
Re: 1.4 citi golf mk1 2007
Check the first relay under the dash just on top of the bonnet catch just stick your hand in there an check the relay
Can you please help me my indicators is blinking fast on the dashboard but no signal is going to the bulps on the outside even with the hazards on no signal but when presing the key to open and lock the car the lightbulb work on the indicators
Looks like your bulbs are blown, what do you mean the bulps are working....Baconjp wrote:Can you please help me my indicators is blinking fast on the dashboard but no signal is going to the bulps on the outside even with the hazards on no signal but when presing the key to open and lock the car the lightbulb work on the indicators
Hazard switch and flasher relay. They work together.Baconjp wrote:Can you please help me my indicators is blinking fast on the dashboard but no signal is going to the bulps on the outside even with the hazards on no signal but when presing the key to open and lock the car the lightbulb work on the indicators
Do you know where to find the flasher relay
Fusebox under the dash on the passenger side, for black vinyl dash, new spec I'm not sure, maybe near the steering column.Baconjp wrote:Do you know where to find the flasher relay
