2004 VW Polo 9N Electrical Issue
Re: 2004 VW Polo 9N Electrical Issue
Did the lights stop flashing as well?
No still went strong
Do you have a transponder key? If u do try the spare key and see if that helps.
No spare key unfortunately. Been driving now for about an hour and as usual when car is hot and running for for a while no problems everything working great
Well nothing else comes to mind. Hope u get this sorted. All the best. Keep us posted.
You think a new BCM?uncivilized wrote: ↑Tue Apr 09, 2019 12:01 pm Well nothing else comes to mind. Hope u get this sorted. All the best. Keep us posted.
Thats why I suggested you trying another one.
If you got one that isn't too expensive then give it a try.
After some research it seems this problem has come up a few times with no real answers, I did however find out that the plug I disconnected on the BCM which allowed the car to start is also the CAN Bus wiring. You think they might be a problem? Also you mentioned there should be no lights on the cluster after removing the BCM but it was still doing the same thing? Is the problem really the BCM then?uncivilized wrote: ↑Tue Apr 09, 2019 12:11 pm If you got one that isn't too expensive then give it a try.
Try unplugging all the lugs and see what happens.
On the BCM you mean? I did, I completely removed it. Still had the cluster going crazy on the ABS and EPC light
If everything was unplugged and the lights went off then im not so sure...did u try taking the car to an auto electrician?
Everything was unplugged but like I said EPC and ABS was still flashing with the buzzer going crazy, just the battery and power steering light went of which allows the car to start. One Auto Elec wants to redo the whole wiring loom the other suggested replacing the negative lead from battery to body which I did and obviously didn’t help at all. Can anyone maybe a recommend a really clued up guy in the Cape Town area?
Sorry man. I'm from Durban. But if u do manage to get your hands on another box please do try it.
Got a BCM from Europe for R240 so will just have to wait a week or so and see, it’s like the car is just getting worseuncivilized wrote: ↑Wed Apr 10, 2019 11:44 am Sorry man. I'm from Durban. But if u do manage to get your hands on another box please do try it.
Wow. That's really cheap. Lets hope this does the trick. Fingers crossed.
Free postage too, so might take longer than a week haha. Yes fingers crossed
+27 84 592 1571 Tawfeeqemile777 wrote:Everything was unplugged but like I said EPC and ABS was still flashing with the buzzer going crazy, just the battery and power steering light went of which allows the car to start. One Auto Elec wants to redo the whole wiring loom the other suggested replacing the negative lead from battery to body which I did and obviously didn’t help at all. Can anyone maybe a recommend a really clued up guy in the Cape Town area?
I had an a4 audi that some stuff died like the lights and wipers. It would not communicate the the bcm. I found the can us cable, a sinlge small wire plug got kicked out by the driver pushing his foot against the side panel. Plugged it back in and the lights and wipers was restored.
So maybe look for breaks in any of the cables leading to the bcm.
Hi guys, the BCM will be arriving soon, the car is an absolute nightmare to drive, can’t even get my fuel cap to open sometimes. Anyway I presume the BCM will need to be coded to the car? Or some things copied from the old one to the new one? Anyone close by that can do this for me, I don’t have proper VCDS that can do this
Sorry without possibly re-reading the entire thread maybe you can drop a hint as to where you are - by either filling in the location field , or maybe putting it in your signature or just saying which area in your request for help. close by where?.
Sorry Panic, I am close to the Cape Town area about an hours drive from Cape Town actuallypanic-mechanic wrote: ↑Fri May 03, 2019 1:26 pm Sorry without possibly re-reading the entire thread maybe you can drop a hint as to where you are - by either filling in the location field , or maybe putting it in your signature or just saying which area in your request for help. close by where?.
well maybe PM a guy called THANAS and see if he can help you.
Yeah I know him Michael I think he’s name was. Might still have he’s number will give him a shout thanks
