Dumping fuel
Dumping fuel
Howzit guys new to the group ... .. so here's the thing I've got a tenaciti 2009 mpi system ... it dumps fuel on a cold start I have been through almost everything I'm sure trying to figure out what's the problem and yet still no luck ... I've changed map sensors I've changed oxygen sensors ...I changed the fuel regulator I've done 4 diagnosis and ive changed the term switch .. what else could be the cause of my car dumping fuel on a cold start and accelerator pressed
- BIGMIG
- Porra Love
- Membership No: 1574
Re: Dumping fuel
PM panic-mechanic he should be able to point you in the right direction.
Re: Dumping fuel
yup, get rid of the MPi. Have had that a bundle of times. I think there is an earth that goes wrong in the box.
Re: Dumping fuel
Thanks guys for the help...I've also changed the exhaust system and still have the issue currently diagnostics says lambda sensor heating short circuit to ground
Also please can you advise what would be needed to change to mp9
Re: Dumping fuel
A bundle of pin locations on the plug for the management.
